What Determines the Charge Needed for a Spark Between Two Objects?
  • Thread starter Thread starter error404
    Electrostatic
The charge needed to generate a spark between two objects is governed by electric field strength, which depends on the distance between the objects and their respective charges; closer proximity requires less charge to create a spark. High relative permittivity materials can store significant electric charge, but this does not imply they cannot hold charge; rather, it indicates their capacity to store energy effectively. Insulators, which have high dielectric properties, prevent electrical attraction and require a strong electric field for charge transfer. Practical applications of these concepts include the use of insulators like electric tape in everyday life. Understanding these principles is essential for exploring electricity further.
error404
hello folks,
Actually I'm not an engineer, but i have a couple of questions regarding electricity and i hope i am posting this in the right forum :)
1- when there's a charged object, that comes close to another object, a spark tends to happen between them, so that the charged body emptys the charge it holds.
My questions is: what is the rule that governs the amount of charge required to generate this spark in respect to the distance between the 2 objects?
2-I was looking for objects with high Relative permittivity and found a table on wikipedia telling that there are objects with an ε over 200,000. does this mean that, these objects cannot hold any charge practically?
thanks guys :)
Hey,
My answer:
1. spark is caused due to electric field breakdown. i.e. every material (such as air) has E-field strength. If E applied is more than this strength. The material breaksdown and material would act as conduct till the E-applied is short. Good example of it is lightning. You can read more about it from wiki.
2. relative permittivity is used for dielectrics. Its technical definition has to do with polarization effects. If epsilon is high it means it can store more power. If you are familiar with capacitors. Power is capacitor is proportional to capacitance. Which in turn is proportional to electric permittivity of the dielectric. So, more the dielectric more energy it can store. Other property is that, more the permittivity of a material slower the propagation speed.
Hope this helps.
utkarsh1 said:
Hey,
My answer:
Hope this helps.
utkarsh1,
thanks for replying me.
regarding the first question, i can understand the concept behind the generation of the spark itself, but i still cannot find a rule that can give me straight numbers for this.
i mean let's assume a distance of 1 meter, between 2 point charges, with air or vacuum between them. what is the required amount of charge of each point in coulombs? (if u can show me a rule or something maybe?)
ok now about the second question, i now understand that the higher ε the material has, it will store more energy, but i am looking for something different here:
I want a material that can stop electrical attraction between 2 objects (isolation) without being charged, what material would do that best??
thx :)
So for each material there is e-field strength (in coulumbs) my EM textbook had this. As for the rule, you can use any rule to find the E-field between two objects. Most common is coulumbs law. This is all theoretical, practically this won't work because there is tiny bit of charge everywhere around you.
I guess bit of incorrect explanation on my part here. So, basically high dielectric is insulator. and insulator prevents currents from interacting. The reason i confused myself and said it would store energy is because if insulator is placed between two conducting plates, the charges build up on plates. So, technically good insulator helps store charge (but this is in cap. only). So basically charge transfer between insulator is difficult and require lot of e-field. sry abt. confusion. insulator is day-to-day life is electric tape.
utkarsh
Hello there,
I am happy to address your questions about electricity.
1. The rule that governs the amount of charge required to generate a spark between two objects is known as the electric field strength. This is determined by the distance between the objects and the amount of charge on each object. The closer the objects are, the stronger the electric field and the smaller the amount of charge needed to create a spark.
2. When an object has a high relative permittivity, it means that it can store a large amount of electric charge for a given electric field. This does not mean that the object cannot hold any charge practically. In fact, many materials with high relative permittivity, such as capacitors, are used to store and control electric charge. The high relative permittivity simply means that the material has a high capacity for storing charge.
I hope this helps answer your questions. Keep exploring and learning about electricity!
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
