Basic Findings of Special & General Relativity
shounakbhatta
Special and General relativity --Basic findings
Hello All,
Kindly note that it is not a home work.
The Special Relativity (SR) and the General Relativity (GR) has some basic findings. I mean to say that say, SR:has some findings like:
(a) The speed of light c is constant.
(b) The faster you move, the clock runs slow.
Similarly GR has some:
(a) Spacetime is curved
(b) The principle of Equivalence.
Can anybody please list what are the findings (or whatever you might call) of both SR and GR?
Thanks.
You cannot consider SR and GR in this way. They are not different theories in that sense. GR postulates that SR holds in local coordinate bases which are transported along the worldlines that represent 'observers'. These worldlines could be in curved spacetime. The 'findings' of SR all emerge from the Minkowski geometry, and this is preserved in local frames.
Another way of thinking about the relationship between SR and GR is that SR is GR in globally flat spacetime, or GR is SR with curved spacetime.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
