kara
- 54
- 0
So the horizontal component of my initial velocity is 20 m/s, and the vertical component of initial velocity is 36.6 m/s
The discussion focuses on calculating the initial velocity components of a projectile given its horizontal and vertical displacements after 2 seconds. The horizontal displacement is 40 m, leading to a horizontal velocity component of 20 m/s, while the vertical displacement of 53 m requires the use of the kinematic equation y = y0 + v0yt - 1/2gt^2 to find the vertical component of the initial velocity, which is determined to be approximately 36.6 m/s. The participants emphasize the importance of correctly applying the acceleration due to gravity as -9.8 m/s² and ensuring that initial velocity is not assumed to be zero.
PREREQUISITESStudents studying physics, educators teaching kinematics, and anyone interested in understanding projectile motion calculations.
Right... the vertical component of the velocity will be zero.kara said:So i know that its v will be 0 m/s at max heigh.
That's right. You are looking for the value of x when y is maximum. Hint: When does it reach the maximum height?kara said:and b/c I am looking for how far its been displaced horizontally from the launch pt. i am looking for x?
You left out part of that equation; it should be:kara said:i plugged in all my values but get stuck at one point with a negative square root:
53 = -1/2(9.8)t^2
