Can an Airplane Take Off from a Moving Runway?
  • Context: Undergrad
  • Thread starter Thread starter huncowboy
The discussion centers around the hypothetical scenario of an airplane attempting to take off from a runway that moves in the opposite direction at a speed equal to the rotation of the airplane's wheels. Participants explore the implications of this setup on the airplane's ability to generate lift and take off, considering various factors such as thrust, rolling resistance, and friction.
  • Some participants propose that the airplane can take off because the thrust from the engines generates forward motion independent of the wheels' rotation.
  • Others argue that if the airplane does not move relative to the air, it cannot generate lift, regardless of wheel speed.
  • A participant questions what counters the effect of the jet engine if the airplane remains stationary, suggesting that the action of the propeller should propel the airplane forward.
  • Concerns are raised about the friction and rolling resistance of the wheels, with some suggesting that these forces could prevent the airplane from accelerating to takeoff speed.
  • There is a discussion about the theoretical implications of using ice as a surface, where reduced friction might allow the airplane to take off more easily.
  • Some participants note that if there is any friction between the wheels and the surface, it would inhibit takeoff, while others clarify that a perfectly frictionless surface would allow for takeoff.
Participants generally disagree on whether the airplane can take off from the moving runway, with multiple competing views regarding the roles of thrust, friction, and rolling resistance. The discussion remains unresolved, with no consensus reached.
Participants acknowledge various assumptions, such as the nature of the moving surface and the effects of friction and rolling resistance, but do not resolve these complexities. The discussion also touches on the practical limitations of engineering such a system.
huncowboy
Hi,
We have been discussing this following problem to the death at a different forum. I figured I will ask the professionally oriented what they have to say about it.
The problem:
The airplane (jet or the other one) is on the special surface, which can run backwards - opposite the direction of the tested airplane ready to take off. The speed of the moving surface is equal the speed of spinning wheels of the airplane at any time that is regulated persistently and efficiently by a special device.
The problem (question): will the airplane be able to run on this surface and then take off?
My take on it is it would, because the propeller is creating the forward motion not the wheel. But some say the wheel would spin so fast that it would create enough friction to counter the effect of the prop. I can't see that happening.
Probabaly this is a base school level question here but please chew in.
Thanks!
I take it you're thinking of a way to make a plane take off without having to travel any linear distance down a runway? Kind of a zero ground-roll take-off?
Obviously, it's not possible. Airplanes do not require groundspeed to take off, they require airspeed. The airspeed is what generates lift and allows the airplane to take flight. The airspeed is, generally, totally independent of the groundspeed.
If the airplane is not moving with respect to the air, it will not generate lift, and will not be able to fly -- no matter how fast its wheels are spinning.
- Warren
The airplane is stationary at start, so is the surface and the wheel.
Then we apply power.
In case the plane will not move my problem is to understand what counters the effect of the jet engine or the propeller. Those move the air backwards even if the plane say would stay at the same point. Where does the energy of tha air hitting the propeller blades go? I think due to action/reaction the prop would make the plane move forward, while it makes the air move backward... while the surface would move also backward increasingly faster.
But that is just me.
Into heating the bearings of the wheels, of course.
- Warren
So that, and the surface friction would be significant enough to stop the airplane? The next question would be how fast is the surface moving backwards at the moment when the airplane is already at full t/o power.
It has to be faster than the t/o speed or even the maximum cruise speed or else the opposing energy is just not sufficient IMO.
Not really surface friction. You mean rolling resistance, which is a dissipative force resulting from the deformation of tires and wheels and bearings and so forth. The (static) surface friction only serves to make the wheels rotate, and is not dependent upon the angular velocity of the wheels. Futhermore, static friction never does any work for a wheel that is not slipping.
This would depend quite strongly on both the airplane's thrust and its rolling resistance.
Why? If the engine is producing x horespower of thrust, you just have to make sure the rolling resistance of the wheels is dissipating x horsepower also. Since the power lost to rolling resistance is variable (we're assuming a perfect moving surface that is capable of any speed), this equality will always happen at some velocity. However, it is entirely possible that you'll simply burn the wheels up before you reach the airplane's maximum thrust.
- Warren
If the wheels are in contact with the ground, this isn't possible. Any attempt to increase the speed of the moving surface will also increase the speed of rotation of the wheels by the same amount.
Try rubbing a roller against a piece of wood, and see what happens. Yep, the roller spins as well.
FZ+, what I think he means is simply that the moving surface can
a) move at any arbitrary velocity
b) be controlled by some control system to make the airplane remain stationary wrt some non-moving point (i.e. an operator standing off to the side of the moving surface).
- Warren
chroot,
What I meant by the speed of the wheel and the surface:
When the airplane takes of at under normal conditions (no backward moving surface)... the resistance created by the wheel is not significant. The airplane will take off after the rollout. Say that speed when the airplane takes of is Vx. At Vx the friction and resistance generated by the wheels is a value. This value will not stop the plane from moving and accelerating to its t/o speed or else we would not have airplanes.
In our example however this force according to you guys (and othwer at the other forum as well) will eventually prohibit the plane from accelerating. In order this be true, the speed of the surface can't be Vx because at Vx we already decided that the wheels don't create enough friction. It must be more than Vx.
Unless I am missing something.
- Warren
upss missed this post. Yes absolutely a, and b, I think is given by the problem although the problem was not created by me.
BTW what if we would change our wheels to scates and the surface would be ICE. In theory it is the same. But in reality I have hard time imagining it.
I agree.
- Warren
If the surface were ice (i.e. it were frictionless), then the surface could move at any velocity and impart absolutely no force on the airplane. The airplane will take off as it normally would. Actually, its ground roll would be a little shorter than normal, since it wouldn't have to fight the rolling resistance of the tires.
- Warren
So the answer is if there is ANY friction between the wheel and the surface it will not take off. Even the slightest. I think even ICE and water has some friction. But if there is zero friction it won't.
I still would like to see a few more persons to take their position.
Right -- assuming, of course, that your moving surface is perfect, and can always go fast enough (ludicrous speed!) to counter the thrust with rolling resistance. In the real world, it would be next to impossible to engineer a surface that could ever move this fast, or accelerate rapidly enough. In addition, the wheels on a real plane would pretty quickly succumb to balance problems and self-destruct.
It does.
Yup. In the limit of zero friction, there is no more rolling resistance, and nothing the moving surface could do would be able to stop the airplane. The moving surface exerts no force in the limit of zero friction.
There's really no position to take -- it either is or it ain't.
- Warren
Thanks!
  • · Replies 127 ·
17K
  • · Replies 34 ·
  • · Replies 116 ·
13K
  • · Replies 69 ·
17K
  • · Replies 124 ·
20K
