Basic question about quantum: Number operator usage
  • Thread starter Thread starter knightpraetor
    Operator Quantum
knightpraetor
So i was working on a homework problem to calculate energy, and i can calculate it directly. But i was thinking it should be easier to use the number operator on the wave function and find out what it's energy should be. The function involved is the initial wave state of a quantum harmonic oscillator. Anyways, it's getting late but i thought i'd ask to see if I'm thinking the right way, and try to solve it more tomorrow. so
ANyways, Asub+ * Asub- *Psi(x) = n * Psi(x)
where Psi is the wave function.
by the definitions of Asub+ and Asub-, i will end up getting
(2m *(Hamiltonian operator ) -m*omega* hbar) / (2m*omega*hbar)) * Psi = n *Psi
i then insert the hamiltonian operator, which is
- hbar^2/ 2m * d^2/dx^2 + V(x), where V(x) for a harmonic oscillator is
kx^2/2
if i do this and multiply by the wave function should it come out to N * the wave function so that i can learn what energy state the function is in?
the wave function at issue is
Psi (x,0) = A (1-2 *sqrt (mw/hbar)*x)^2 * e^ (-mwx^2/2hbar)
from griffith 2.41
i'm pretty sure i can solve it just by calculating the integral manually, but that seems inefficient..i thought since that in my notes it gave me a "number operator" and I have the energy for any given N, then that should be faster
Could you write everything using LaTex ? I have troubles understanding what you wrote above.
Daniel.
i would love to, except i don't know what latex is or how to use it. Can you link me a tutorial on it?
found it..working on it
ANyways, a_+ a+- /Psi (x) = n * /Psi (x)
by the definitions of a_+ and a_-, i will end up getting
/frac{2m/hat(H) -m/omega */bar(h}{2m/omega/bar(h)} /Psi = n /Psi <br /> <br /> i then insert the hamiltonian operator, which is <br /> -/frac{/bar(h)^2} {2m} * /frac {d^2}{dx^2} + V(x), where V(x) for a harmonic oscillator is <br /> /frac{kx^2}{2}<br /><br /> <br /> if i do this and multiply by the wave function should it come out to N * the wave function so that i can learn what energy state the function is in?<br /> <br /> the wave function at issue is <br /> <br /> /Psi(x,0) = A (1-2x /sqrt(/frac{m/omega}{/bar(h)}))^2 * e^ -/frac{m/omega x^2}{2/bar(h)}<br /><br /> from griffith 2.41<br /> <br /> i'm pretty sure i can solve it just by calculating the integral manually, but that seems inefficient..i thought since that in my notes it gave me a "number operator" and I have the energy for any given N, then that should be faster
ANyways,
a_+ a_- \psi(x) = n \psi(x)
where \Psi is the wave function.
(2m \hat H -m \omega \hbar) / (2m \omega \hbar)) \Psi= n \Psi
- \frac{\hbar^2} {2m} \frac{d^2}{dx^2} + V(x), where V(x)=\frac{kx^2}{2} for a harmonic oscillator is
\Psi (x,0) = A (1-2 \sqrt {\frac{m \omega}{\hbar}} x)^2 e^ {-\frac{m \omega x^2}{2 \hbar}}
from griffith 2.41
I tried to do it for you - if something's wrong, perhaps you can quote from my posting and try to correct it yourself? Latex is very straightfroward, if you know some things. :smile:
You have to do "\", not "/". :wink:
lol you i didn't notice it either..i just looked for other things..slashes are all the same to me:)
and thanks for the help..i'll figure it out bit by bit
I think this only works if \Psi is an energy eigenstate, which it doesn't have to be. Consider for example the wavefunction \Psi(x) = \phi_1 + \phi_2, where \phi_n is the nth energy eigenstate, but \Psi is no (energy) eigenstate at all.
