Battery voltage increases when voltmeter connected
The discussion centers on the phenomenon where connecting a AA rechargeable battery to a voltmeter results in a gradual increase in voltage readings. Participants noted that this could occur due to a failing voltmeter battery, which can affect measurement accuracy. Additionally, it was mentioned that external factors, such as heat from a person's hand, can enhance the chemical reactions within the battery, leading to temporary voltage increases. Ultimately, ensuring the voltmeter is functioning properly is crucial for accurate voltage readings.
  • Understanding of basic electrical concepts, including voltage and battery chemistry.
  • Familiarity with digital voltmeters (DVM) and their operation.
  • Knowledge of rechargeable battery types, specifically AA batteries.
  • Awareness of factors affecting battery performance and measurement accuracy.
  • Investigate the effects of temperature on battery performance and voltage readings.
  • Learn about common issues with digital voltmeters and how to troubleshoot them.
  • Research the chemical processes in rechargeable batteries that affect voltage output.
  • Explore best practices for measuring battery voltage accurately using a DVM.
Electronics enthusiasts, electrical engineers, and anyone involved in battery testing or troubleshooting voltmeter issues will benefit from this discussion.
damosuz
When I connect a AA rechargeable battery directly to a voltmeter, voltage increases slowly, regardless of the way I connect it. I can't figure out why.
Increases from what to what? And what do you mean by "regardless of the way I connect it"? There aren't that many ways to connect a DVM to a battery... :smile:
Likes sophiecentaur and anorlunda
This happened to me last year when I was measuring the voltage on a car battery.
It turned out the battery in my voltmeter was going dead.
Replacing the battery in the voltmeter made the problem go away.
Likes sophiecentaur and berkeman
Sometimes the heat from your hand is enough to boost the chemical reaction in the battery increasing the voltage.
Correctly anyway. I wondered the same thing.
  • · Replies 19 ·
  • · Replies 21 ·
