Behaviour Under Simple Transformations
  • Thread starter Thread starter haleym
    Transformations
The discussion focuses on finding the equation of a sine function with specific transformations, including a vertical displacement of 2 units down, a horizontal phase shift of 60 degrees to the right, a period of 30 degrees, a reflection in the y-axis, and an amplitude of 3. The proposed solution is Y = 3 sin(30x - 60) - 2, but there is confusion regarding the reflection and the calculation of the period. It is clarified that a reflection in the y-axis means multiplying the function by -1, and the period is determined by the coefficient of x in the sine function. The correct phase shift is identified as 2, not 60, leading to the correct expression Y = 3 sin(30(x - 2)) - 2. Understanding these transformations is crucial for accurately representing the sine function.
haleym
Find the equation of a sine function that has a vertical displacement 2 units down, a horizontal phase shift 60 degrees to the right, a period of 30 degrees, a reflection in the y-axis and an amplitude of 3.
2. The attempt at a solution
Y = 3 sin (30x- 60) -2
I'm not completely sure how to demonstrate a reflection or how to calculate the period...
Reflection in the y-axis just means that what is positive becomes negative. If f(x) was 2, it becomes -2. So just multiply through by -1.
The period is given by the number in front of x. If sin(x) has a period of 2pi or 360 degrees, sin(kx) has a period of 2pi/k or 360/k degrees. So for a period of 30 degrees, 360/k = 30, for example, or in radians, 2pi/k = pi/6.
Actually, now that I think about it, one would probably always say that a sine function has a period of 360 degrees because it represents a rotation. A rotation is always a whole rotation. I don't have a clear conception of how one would describe the period of a sinusoidal function, exept to refer to whatever coordinates are being used. If x represents degrees (and sin expects its argument in degrees), then sin(2x) has a period of 180 degrees, even though it sounds strange to say that.
Be careful about the phase shifts, too. Because the phase shift of
Y = 3 sin (30x- 60) -2,
as you wrote it (ignoring for a moment that the 30 in front of the x is wrong) is not 60, but 2.
The generic form for a sinusoid (as I learned it) is
f(x) = a\sin (b(x - h)) + k
where:
|a| indicates a vertical stretch/shrink,
2π/b represents the period,
h represents the phase shift, and
k represent the vertical translation.
So what you have is
Y = 3 sin (30x- 60) -2 = 3 sin(30(x - 2)) - 2,
so the phase shift here is actually 2.
Thank you!
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
