Have you heard of the mirage effect on the sea?
  • Thread starter Thread starter Timothy Schablin
    Light
The mirage effect on the sea allows distant objects, like cities, to be visible beyond the horizon due to atmospheric refraction. This phenomenon occurs when light bends as it passes through layers of air with varying temperatures, particularly when warm air overlays cooler water. As a result, visibility can extend further than normal, making it possible to see objects that would typically be obscured by Earth's curvature. Additionally, the sun appears to set later than its geometric position due to this bending of light. Understanding this effect enhances knowledge of optical phenomena in atmospheric science.
Timothy Schablin
I remember reading about how a city could be seen across a sea at certain times. But normally would not be seen because of Earth's curvature. At certain times however, it could be seen because of light bending. I can't remember what the cause was though.
Anyone know about this and what caused it?
Science news on Phys.org
There is always some refraction due to the atmosphere that causes light to bend in its path and allows you to see a bit beyond the physical horizon. This effect can be increased when there is a temperature gradient in the air, such as when warm air is sitting over a cool body of water. In these cases the distance you can see past the horizon becomes further than it would under normal conditions.
Likes Charles Link
It might be of interest that the sun is already geometrically set, just about the time when it appears to start to set.
The word for what the otters described is mirage. Read more here https://en.m.wikipedia.org/wiki/Mirage
Likes Charles Link
