Bernoulli equation and velocity problem
The discussion centers on calculating the pressure energy term in the Bernoulli equation, emphasizing that pressure is expressed in N/m² (Pascals) and is integral to energy calculations. To derive pressure energy, one must multiply pressure by volume, converting it into joules, as energy is defined per unit volume. The standard form of Bernoulli's equation includes a pressure term rather than a separate pressure energy term, and the kinetic energy is calculated using mass and velocity. An example illustrates that 1 m³ of gas at 100 kPa equates to 100 kilojoules of potential pressure energy. Understanding these conversions is crucial for applying the Bernoulli equation effectively.
malikengg
In the Bernoulli equation, i know that velocity is in m/s and mass in N which gives energy in joules. Likewise potential energy id also in joules being mgh. In pressure energy what are the variants? i.e what is formula for calcualting the pressure energy term in the equation? If we compute everything in joules, then how the pressure energy would be calculated? i want to know formula for calculating the pressure energy term in the equation.
malikengg said:
In the Bernoulli equation, i know that velocity is in m/s and mass in N which gives energy in joules. ...
The terms in Bernoulli's equation are stated as energy per unit volume. (Note that density is mass per unit volume). To convert these terms to energy terms, you need to multply by some amount of volume.
yeah, okay..but i wanted to know how to calculate the pressure energy term in the equation. e.g to calculate the kinetic energy, we used mass and velocity (m*v^2/2). Likewise how the pressure energy would be calculated. If we are given an initial value of pressure, say 100kPa (N/m^2), in some problem, what value to substitute in the equation?
The standard form of Bernoulli's equation includes a pressure term, not a pressure energy term. The velocity term is 1/2 density velocity2 (density as opposed to mass). You need to multiply the terms by some amount of volume to get energies.
So if there was 1 meter3 of gas at 1 Pa, then the potential pressure energy would be 1 (N/m2) (m3) = 1 N m = 1 joule. If there was 1 meter3 at 100 kPa, the potential pressure energy would be 100 kilo-joules.
Welcome to Physics Forums.
People seem to be missing what you are asking. If you are using kg, m, and s units, then use units of N/m^2 for pressure -- which is equivalent to 1 Pa.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
