Can't Make Sense of Bernoulli Equation
That's a linear equation for z. Solve that and you can get y back by y1-n= y-1= z.In summary, the given conversation discusses a Bernoulli equation with P = 1/x, Q = 3x^2, and n = 2. The equation is reduced to a linear equation after dividing by y^2 and making the substitution z = y^-1. The substitution is achieved through the chain rule and the resulting linear equation can be solved to obtain the original equation for y. There is a discrepancy in the value of P, which should be 1/x instead of 1/2.
snowJT
117
it...just...does...not...make...the...slightest...sense...to...me...:confused:
Here it goes...
[tex]y' + \frac{y}{x} = 3x^2y^2[/tex]
This is a Bernoulli equation with [tex]P = \frac{1}{2}[/tex], [tex]Q = 3x^2[/tex], and [tex]n = 2[/tex]. We first divide through by [tex]y^2[/tex], obtaining...
[tex]\frac{1}{y^2} \frac{dy}{dx} + \frac{y^-^1}{x} = 3x^2[/tex]
We substitute [tex]z = y^-^1[/tex] and
[tex]\frac{dz}{dx} = -y^-^2\frac{dy}{dx} \Longrightarrow \frac{dy}{dx} = -y^2\frac{dz}{dx}[/tex]
Substituting... [tex]-\frac{dz}{dx} + \frac{z}{x} = 3x^2 \Longrightarrow \frac{dz}{x} - \frac{z}{x} = -3x^2[/tex]
I'll stop there... two things I don't get... how does [tex]P = \frac{1}{2}[/tex] and how does that substitution work...
If you can help, I would really appreciate it.
Yes, for that sentence to make any sense, you would have to know what a "Bernoulli equation" was, wouldn't you? Not remembering exactly and not having a differential equations textbook immediately handy, I "googled" on "Bernoulli differential equation" and get (from Wikipedia)
"an equation of the form y'+ P(x)y= Q(x)yn for n not equal to 1"
There's obviously an error- either in your source or in your copying. That is a Bernoulli equation with P(x)= 1/x, not 1/2.
Dividing a Bernoulli equation by yn and then making the substitution z= y1-n always reduces the equation to a linear equation.
As for "how the substitution works" I don't know what more to say. It is shown pretty clearly there. What are you not understanding? (Other than that "P(x)= 1/2" should be P(x)= 1/x".)
Do you see how they go from z= y-1 to dz/dx= -y-2dy/dx? That's straight forward "chain rule". Then, of course, y-2dy/dx in the differential equation becomes -dz/dx. y-1/x is simply z/x. The differential equation y-2dy/dx+ y-1/x= 3x2 becomes -dz/dx+ (1/x)z= 3x2.
Thank you.The Bernoulli equation can seem confusing at first, but with some understanding and practice, it can become easier to comprehend. Let's break down the steps and try to make sense of it.
First, let's look at the equation given: y' + \frac{y}{x} = 3x^2y^2. This is in the form of a Bernoulli equation, which has the general form of y' + P(x)y = Q(x)y^n. In this case, P(x) = \frac{1}{x} and Q(x) = 3x^2.
Now, to solve a Bernoulli equation, we use a substitution to transform it into a linear equation. In this case, we choose z = y^-1, which means that y = z^-1. This substitution allows us to rewrite the equation as \frac{dz}{dx} = -y^-2\frac{dy}{dx} \Longrightarrow \frac{dy}{dx} = -y^2\frac{dz}{dx}. This is known as the Bernoulli substitution.
Now, substituting y = z^-1 into our original equation, we get -\frac{dz}{dx} + \frac{z}{x} = 3x^2. This is now a linear equation, which we can solve using standard techniques.
As for why P = \frac{1}{2}, this is because we are dividing the original equation by y^2, which is equivalent to multiplying by y^-2. In other words, we are dividing the coefficient of y' by the power of y in the original equation, which gives us P = \frac{1}{2}.
I hope this explanation helps to make sense of the Bernoulli equation for you. It may take some practice and understanding of substitution and linear equations, but with time, it will become clearer. Keep working at it and don't hesitate to ask for help if you need it. Good luck!
1. What is the Bernoulli Equation?
The Bernoulli Equation is a mathematical relationship that describes the conservation of energy in fluid flow. It states that the total energy of a fluid system remains constant as it moves from one point to another, and is equal to the sum of its potential, kinetic, and flow energies.
2. Why is it difficult to make sense of the Bernoulli Equation?
The Bernoulli Equation can be difficult to make sense of because it involves multiple variables and terms, such as pressure, velocity, and density, which can be confusing to understand and apply correctly. Additionally, it requires a strong understanding of fluid mechanics and calculus to fully grasp its implications.
3. How is the Bernoulli Equation used in science?
The Bernoulli Equation has a wide range of applications in various scientific fields, including aerodynamics, hydraulics, and meteorology. It is used to analyze and predict fluid behavior in pipes, channels, and other systems, and can also be used to design and optimize fluid flow in engineering applications.
4. What are some common misconceptions about the Bernoulli Equation?
One common misconception about the Bernoulli Equation is that it only applies to ideal, incompressible fluids. In reality, it can be applied to a wide range of fluid types, including compressible and viscous fluids. Another misconception is that the equation only applies to steady-state flow, when in fact it can also be used to analyze unsteady or non-uniform flow.
5. How can the Bernoulli Equation be simplified for easier understanding?
One way to simplify the Bernoulli Equation is to break it down into its individual terms and analyze each one separately. Another approach is to use visual aids, such as diagrams or animations, to help visualize the different components of the equation and how they relate to one another. Additionally, practicing with real-world examples and applications can help improve understanding and make the equation more relatable.
  • Differential Equations
