Bernoulli's Equation and water rockets
The discussion revolves around the application of Bernoulli's equation to calculate the exhaust velocity of water in water rockets. Participants explore the relationship between water volume, pressure, and exhaust velocity, considering both experimental observations and theoretical models.
  • One participant notes that increasing water volume results in lower exhaust velocity, attributing this to the energy from pressurized air.
  • Another participant asserts that mass is involved in the calculation through density, suggesting that the volume of water does not affect the velocity calculation.
  • Some participants argue that the pressure decay during water expulsion affects the velocity, with less gas leading to a higher rate of pressure reduction.
  • A suggestion is made to model gas expansion as adiabatic, proposing that pressure and velocity can be determined at various points during water expulsion.
  • There is a discussion about the clarity of notation when referring to changes in volume versus velocity in the context of mass flow rate.
  • One participant emphasizes understanding the role of mass when pressure is constant to better grasp the more complex situation when pressure is not constant.
  • Confusion arises regarding the attribution of statements, with one participant clarifying that they are not the original poster.
Participants express differing views on the implications of water volume on exhaust velocity and the role of pressure dynamics. The discussion remains unresolved, with multiple competing perspectives on the application of Bernoulli's equation and gas expansion modeling.
Limitations include the dependence on assumptions about pressure constancy and the complexity of modeling gas expansion in relation to water expulsion dynamics.
MigMRF
So I'm playing around with some water rockets and I'm trying to figure out how fast the exhaust velocity of the water is. I've had an experimental approach using high fps camera to record and analyse (using tracker) the exhaust velocity. I'm using a 0,5 l soda bottle with 0,085 L ; 0,135 ; L 0,185 L and 0,235 L water. So far I've found, that more water means less exhaust velocity (the pressure is exactly the same at 1,8 bar). This makes sense, because the acceleration of the water comes from the energy of the pressurized air.
However I've found, that a lot of people use the Bernoullis equation (rewritten) to calculate the exhaust velocity with the formula:
However there is no mass involved here?
The denominator is density. Mass is 'involved' there.
Indeed, but then it doesn't matter if there is 50 ml of water or 450 ml of water. This makes no sense to me tbh.
It doesn't matter, for the velocity calculation.
I suspect that the reason that more water results in lower velocity is because there is less gas. The pressure decays as the water is expelled - that rate of reduction is higher if there is less gas (initially). The initial velocities should be the same.
Ahh, thanks! That makes perfectly sense!
I was wondering if there is a good model for pressure as a function of time?
If you have density and you want mass, you just multiply by volume. If you have velocity and you want volumetric flow rate, multiply by cross sectional area. Like any equation/model, Bernoulli's equation is adaptable, you just have to ask it the question you want it to answer!
If you have nine times as much volume you also have nine times as much mass. Think of it this way. When 450 mL of water is expelled you can imagine breaking that stream of ejected fluid into nine equal 50 mL segments. The last segment, for example, is ejected at the same speed as the first segment, provided the pressure difference is the same.
Yes, but this is not the situation for a 1/2 liter bottle initially filled halfway with liquid. The gas pressure (driving the flow out the nozzle) decreases as the liquid is discharged and the gas expands.
You can use Bernoulli to determine the initial nozzle velocity (pretty much pressure head becomes velocity head) but to solve for the time-dependent velocity you have to also model the expansion of the gas.
For the gas expansion, I'd just model it as adiabatic expansion, so for air, p*v^1.4 = constant. You can get dv/dt from the exhaust velocity and nozzle diameter, so from that, you should be able to figure out the pressure (and velocity) at all points during the expulsion of the water.
Yeah, that might actually be a solution. Just to make sure, when you write dv/dt are you saying v as velocity or do you mean V as in volume. It would make more sense if the change in volume with respect to time is related to the mass flow rate
You introduced the equation ##v_{ex}=\sqrt{\frac{2(p_{in}-p_{out})}{\rho_w}}## into this discussion, and wanted to understand the role played by mass. I tried to explain that to you.
The fact that that ##p_{in}## is not constant in your particular application of that equation has no bearing on the explanation. In other words, try to understand the role played by mass when ##p_{in}## is constant so that you can then understand the more complicated situation when it's not constant.
I meant volume, but I can see how that notation was unclear. You can also of course obtain velocity, but you also have to account for the fact that the mass is non-constant.
I think you have me confused with the OP.
  • · Replies 41 ·
  • · Replies 26 ·
