alan_longor
- 29
- 3
i have a frame-buffer , and i want to draw a line using assembly language . i cannot work with decimal numbers . what's the best and most efficient method ?
thank you .
thank you .
Sorry, but I'm not tracking your question. What kind of "frame buffer"? What are you running your assembly language program on? What IO do you have? Where and how are you drawing a line? Physically on paper? On an LCD display? What kind of display?alan_longor said:i have a frame-buffer , and i want to draw a line using assembly language . i cannot work with decimal numbers . what's the best and most efficient method ?
thank you .
berkeman said:Sorry, but I'm not tracking your question. What kind of "frame buffer"? What are you running your assembly language program on? What IO do you have? Where and how are you drawing a line? Physically on paper? On an LCD display? What kind of display?
Much more information and maybe some pictures or links would make it much easier to answer this for you...
What is the format of the frame buffer? Can you post a link to it? How do you change the value of each pixel from OFF to ON? Or is there a grey scale number associated with each pixel? Is upper left on the display (0,0)?alan_longor said:thank you for your attention Berkeman , i am using AVR assembly , and i am attempting to write this line on a TV screen , the frame buffer is 320x200px in size . it's monochrome so one bit represents a pixel . the protocol is PAL . and i am using an Atmega1284p .
i managed to get the protocol running and getting the image on the screen using interrupts . now i want to draw lines . storing things in memory and all is not a problem . since i can address any pixel on the screen easily , the problem now is in the method i will be using to draw the line . i want the most efficient way possible . the usual way "y= ax+b" is not efficient at all .
thank you .
berkeman said:What is the format of the frame buffer? Can you post a link to it? How do you change the value of each pixel from OFF to ON? Or is there a grey scale number associated with each pixel? Is upper left on the display (0,0)?
What will the inputs to your program be? End points of the line? An equation like the one you mention? How often will the line image change? Will you be trying to move the line around on the display in real time?
That info helps a lot. But once you write the image into the frame buffer, you don't have to keep re-writing it, do you? Just when you want to draw a new line, right? And again, what will be the input to your program to tell you what line to calculate? Just the two endpoints?alan_longor said:the frame buffer takes 8000bytes of SRAM . every byte represents 8 pixels . every row is 40 bytes in size . i am using the SPI peripheral for this , since it can do automatic shifting quite fast . so i supply the byte to the SPI registers then set the transmission , this will get the needed data on the DATA OUTPUT pin of the SPI which will be fed to a register ladder . a 0 bit is black and 1 bit is white . at this point , the program only draws the line , that's it . then the interrupts will just continue supplying the correct signal in time using the set frame buffer . this is just a test program .
my problem is not technical , i need a good algorithm to draw the line .
thank you .
you only write the info once , you write it in the frame buffer . then the ISR code will continuously display the frames in time .berkeman said:That info helps a lot. But once you write the image into the frame buffer, you don't have to keep re-writing it, do you? Just when you want to draw a new line, right? And again, what will be the input to your program to tell you what line to calculate? Just the two endpoints?
The most accurate method to draw a line is by using a straight edge, such as a ruler or T-square, and a fine-tipped pencil. This ensures that the line is straight and precise.
If you do not have a ruler or straight edge available, you can use a piece of string or thread to create a straight line. Simply hold the string tight between two points and draw along the string with a pencil. You can also use a piece of paper or cardstock to create a makeshift straight edge.
While it is possible to use a pen to draw a line, it is not recommended as it can be difficult to erase or correct any mistakes. Pencils are a better option as they can easily be erased or sharpened for a finer line.
To draw a curved line, you can use a compass or a French curve tool. These tools allow you to create smooth and precise curved lines with ease. You can also use freehand techniques for more organic and natural-looking curves.
To ensure your lines are parallel, you can use a T-square or a parallel straight edge. These tools have built-in guides that help you keep your lines parallel to each other. You can also use a ruler and measure the distance between your lines to ensure they are parallel.
