Best Physical Means of Storing Kinetic/Mechanical Energy
The discussion centers on identifying the most effective device for storing energy, particularly in relation to size. Key points include the consideration of various metrics such as power density, energy density, and storage efficiency. Participants suggest different energy storage methods, including springs, flywheels, and gravitational systems like hydroelectric dams. The conversation emphasizes the need for clarity on whether the focus is on energy per volume or power per volume, noting that achieving both simultaneously is not feasible. There is also mention of alternative energy sources, such as gasoline, for mobile applications. Overall, the dialogue explores the complexities of energy storage solutions and their specific applications.
BasketDaN
Meaning springs and such; what specifically is the strongest (in relation to size) device for storing this energy?
Thanks
a space shuttle... before u break off the Earth's atmoshpere try jumping off that thing... and feel the POWER -in case u won't be hit by a heart attack first-.
nothing is really comin' up to my mind but springs... u can make a very big one and a small one... if ur askin' about qualities then, it's ur choice because logically u can imagine anything!
if ur doing a project or something then try considering a gun's spring that fires the bullet when u trigger (Sniper Rifles are the best example)
It's unclear exactly what you mean by strongest. Here are some possibilities:
Power Density (Power per Mass)
Power Density (Power per Volume)
Energy Density (Energy per Mass)
Energy Density (Energy per Volume)
Storage Efficiency (Energy out per Energy in)
Do you consider a fast moving object to be 'energy storage'?
Do you consider moving up to be 'energy storage'?
Do you have a particular application in mind?
If you want portable storage, then flywheels would probably be best.
If you can leave it in one place, just use gravity. Raise a heavy object to some high elevation. You can even make it a fluid, such as the storage behind a hydroelectric dam.
But why would it have to be in mechanical form? Just use gasoline, and convert it to mechanical when needed.
It needs to be mobile... and what I'm looking for is either the highest energy per volume or power per volume.
Pick one, you can't have both.
Either meaning I don't know which one... so if you know one or both, that'd be great.
