Biehle's Nova Physics page 3 error with volume calculation?
The discussion centers on a potential error in the volume calculation for 0.4 kg of oxygen gas at specified temperature and pressure in the Nova Physics textbook. The textbook arrives at a volume of 24 L, while users consistently calculate around 25 L or 25.6 L using the ideal gas law. A key point of confusion is the transition from a denominator of 32x12 to 8x50 in the textbook's calculations, which some believe may indicate a misprint. Adjustments for rounding and different gas constant values also contribute to the discrepancies in results. Overall, participants suggest that the textbook's final calculation may be incorrect.
thatrunner
1. The problem statement, all vbles and given/known data
So I'm going throught the Nova Physics book and I'm wondering if there's a mistake in calculation. The question reads: How much volume does 0.4kg of oxygen gas take up at T= 27 degrees Celsius and P= 12 atm (gas constant R = 0.0821 L atm/ K Mol).
V= nRT/ P
the text's last two steps for this calculation are: 0.4x1000x0.08x300 / 32 x 12
the last calculation is: 4x8x300 / 8x50 giving an answer of 24 L.
Where on Earth did the 8x50 denominator come from?
I keep coming up with 25L, but the textbook calculates the volume to be 24L.
Thanks in advance for any help offered :)
V= nRT/ P
It may be a rounding problem. I get 25.6 litres.
If you want to use V = nRT/P you have to use R = 8.3145 Nm/mol K and P in Pascals (N/m) with 1 atm = 101,325 N/m. Volume will be in m^3 so multiply by 1000 to get litres
n = 400g/(32 g/mol) = 12.5 mol
P = 12 x 101,325 = 1,215,900 N/m
T = 300 K
R = 8.3145 J/mol K
V = 1000 x 12.5 x 8.3145 x 300/1.216e6 = 25.6 L.
AM
Thanks Andrew for taking the time to respond.
Yes, without rounding off the initial figures, I come up with an answer of 25.6 L.
The last stage in calculations in the book confused me when it moved from having a 32x12 denominator to a denominator of 8x50... I think the last step contains a misprint.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
