Billiard Ball backspin (draw English) - Rigid body dynamics
The discussion focuses on the dynamics of a billiard ball struck by a cue, specifically addressing the ball's angular velocity, the transition to natural roll, and the work done by friction. For the initial angular velocity (omega0) after the hit, it is calculated using the relationship omega0 = (5/3)(v0/r), where v0 is the ball's velocity post-impact. The velocity at which the ball transitions to natural roll is determined by analyzing linear and angular accelerations over time, leading to the expression t = (v0 - omega0*r)/(-3/2*mu_k*g). The work done by friction during the ball's movement until it starts rolling is also discussed, emphasizing the importance of understanding the relationship between linear and angular motion. Overall, the thread provides a detailed examination of the physics involved in billiard ball dynamics.
Bonulo
I've been presented with the following problems, and would like some help/affirmation:
SITUATION:
A billiard ball with mass m and radius r is in rest on a horizontal table. The ball is hit with a billiard cue the height r/3 above the table, and has the velocity v0 immediately after the hit.
The force from the cue F remains horizontal during the hit and the contact between cue and ball is short-termed. The kinetic coefficient of friction between the table and the ball is mu_k
PROBLEM a) Determine the ball's angular velocity omega0 immediately after the hit.
Since the below-c.m. hit will give the ball backspin (draw English), the ball won't have natural roll. Therefore, I can't use the simple equation v0 = omega0*r, since that relationship only exist in natural roll.
Instead, I have to use Newton's 2nd law, sum_F = m*a and the rotational equivalent sum_tau = I * alpha, where tau is torque (around the c.m.), I is moment of inertia of the ball and alpha is its angular acceleration.
(1) sum_F = m*a <=> sum_F = m*alpha*r
<=> F - mu_k*m*g = m*alpha*r
(2) sum_tau = I*alpha <=> r*F - 2/3*r*mu_k*m*g = (2/3)*m*r^2*alpha
The two expressions each have only one unknown variable, alpha. In (1) alpha is the translational contribution to the angular acceleraton, and in (2) its the rotational contribution to the angular acceleration. Sum_alpha can now be determined. The hit has the duration dt, so omega0 = sum_alpha * dt. By substituting the expression for alpha into that equation I ought to have determined omega0. Right?
PROBLEM b) What's the velocity of the ball when it beings to do natural roll?
The roll is natural when v = omega * r. Since the v0 and r is known, I should then be able to determine expressions for v and omega from the kinematic equations for the two types of motion. I guess the rolling friction can be ignored, since the needed coefficient isn't given. Therefore, there is no horizontal force. Right?
PROBLEM c) Determine the work of the friction force during the ball's movement until it starts rolling on the table.
The ball starts at the angle 0 and reaches an angle theta. The torque is constant, since the kinetic friction is constant. Then the work done by the friction force must be W_f = tau*(theta-0) <=> W_f = tau*theta. Right?
:shy:
They want you to find the angular velocity immediately after the impact. Think of it this way. The cue exerts an impulse on the ball (F \Delta t) that imparts the given linear momentum. Now consider the angular impulse that that force exerted to find the angular momentum after impact.
Yes. Once you've properly found the initial angular and linear speed of the ball, apply Newton's 2nd law for translation and rotation. (What's the only horizontal force acting on the ball?) What you call "natural roll" is also called "rolling without slipping"; you are solving for the speed at which that condition is met.
I'd find the work done by friction by finding the change in total kinetic energy.
Problem a)
The angular momentum after the impact is L=I \omega, but what is the angular impulse? The net torque? Otherwise, I haven't found examples or equations with the angular impulse in the textbook.
Just like linear impulse is F \Delta t, angular impulse is \tau \Delta t. Given "F", what torque does it exert?
The que force F exerts the torque 2/3 r F, and the kinetic friction force f exerts a resistive torque -r f, so that the net torque is r (2/3 F-f), or r (2/3 F - \mu m g).
Right. But I would assume that the duration of impact is very short; so short that the ball has yet to move. Ignore the kinetic friction for part a.
Yeah, of course :) That must be the justification for that information.
Then; the (linear) impulse is F dt, the angular impulse is \tau dt = 2/3 r F dt and the angular momentum is L = I \omega.
Right! (Where "r" in this case is really "2r/3". :smile: )
Yes, I just corrected it. But - isn't the angular momentum the same as the angular impulse?
Merely using \tau = dL/dt gives \tau dt = L - or doesn't it? This gives \omega_0 = (2/3 F dt)/(2/5 m r).
OOOOO. I found it! If you want, a while back I found this paper that has tons and tons of this stuff all on pool. It might be in there.
Yes. \tau \Delta t = I \Delta \omega = I \omega_0.
Simplify that further. (Write F dt in terms of v_0.)
Well, yeah.. I'd like to see it. I've found some PDF's myself too.
Its called Amateur Phyiscs for the Amateur pool player. (its not amateur)~107 pgs
Is it neccessary? Since the quantity F is mentioned in the symbolic description, it's considered known.
I guess it should be simplified via v_0 = a dt, and F = m a = m v_0/dt. And also the rotational contribution, v_0 = r \omega and \tau dt = I \omega_o.
http://www.physics.ohio-state.edu/~penningt/262/ps/apapp.pdf#search='amateur%20physics%20for%20the%20amateur%20pool%20player
Heh, I found that. It's a top Google hit. I didn't find anything directly applicable in it though.
While F is mentioned, I wouldn't call it "known". What you know is the impulse, not the force.
That won't help, since you don't know F or \Delta t. But you do know that the impulse F \Delta t = m v_0; use that to eliminate those unknowns (F & \Delta t) from your expression for \omega_0.
Then: \omega_0 = (2/3 v_0)/(2/5 r) - ?
Yes: \omega_0 = (5/3) (v_0/r)
Thanks for the help.
Problems
I'm having problems with b) and c), and the assignment's due tomorrow!
In b) - there is constant acceleration (also angular), but - the rotational velocity changes direction, so I'll have to use two periods of time t, right? One for the time up to the point where the rotational velocity \omega = 0, and one for the time from that point and up to the point where there's natural roll. If natural roll doesn't start immediately, which I don't think it does.
The c) should be quite easy - but it does involve the result from b), so I can't do it before b) is solved.
Bonulo said:
SITUATION:
PROBLEM a) Determine the ball's angular velocity \omega_0 immediately after the hit.
\omega_0 = 5/3 v_0/r
The way I would approach b) is to find expressions (based on the linear and angular accelerations) for the linear and angular speeds as a function of time. Then solve for the time at which the "natural roll" condition is met.
I get the following expression for the time:
t = (v_0 - \omega_0 r)/(-3/2 \mu_k g)
Where the 0 suffix indicates the velocities immediately following the shot, and the \mu_k is the coefficient of kinetic friction (exerted during the slide). Does it seam reasonable?
(Sorry for the delayed response... had a bit of a snowstorm to deal with. :smile: )
Several comments:
(1) Once again, express \omega_0 in terms of v_0.
(2) Signs matter! Realize that in the "natural roll" condition, \omega and v must have the same orientation. But in this problem, \omega_0 is actually going opposite to v_0.
(3) Once you get the correct t, solve for the final speed of the ball. Your answer should be in terms of v_0. Once again, signs matter.
