Binomial alternating series- even numbers
The discussion centers on the evaluation of the binomial alternating series for even values of n, specifically questioning why the series does not equal zero for n = 4. Participants clarify that the series should indeed sum to zero, as demonstrated by the calculation for n = 4, which yields 1 - 4 + 6 - 4 + 1 = 0. The confusion arises from the middle term, \(\frac{4!}{2!2!}\), which does not cancel out as it does in odd cases. It is emphasized that for even n, the terms do not cancel in the same manner as they do for odd n, but the overall sum remains zero. The key takeaway is that the series holds true for both even and odd n, despite the differing cancellation behavior.
QuantumP7
Ok, I know that (-1)^r \binom {n} {r} is supposed to equal 0. But I have plugged some numbers into this series, and this doesn't seem to be true for even numbers of n? Like for n = 4 and r = 4, I have:
1 - \frac{4!}{1!3!} + \frac{4!}{2!2!} - \frac{4!}{3!1!} + \frac{4!}{4!}. The \frac{4!}{2!2!} seems to be in the way. For even numbers, the \frac{n!}{(n/2)!(n/2)!} does not seem to cancel out, resulting in the series not being equal to zero. Am I doing something wrong at \frac{n!}{(n/2)!(n/2)!}?
1 - \binom {n} {1} + \binom {n} {2} - \binom {n} {3} + \cdots + (-1)^r \binom {n} {n} = 0
See #1.
Hi QuantumP7! :smile:
You're expanding (1 - 1)n sing the binomial theorem, so obviously it has to be zero?
Yes it is … your example for n = 4 goes 1 -4 6 -4 1 = 8 - 8 = 0.
Write out a Pascal's triangle and check as many rows as you like! :wink:
It seems to be in the way of what? The other terms in that series don't cancel out in any natural way.
When you have an even number of terms, expanding (1-1)n is trivial because you just get an n choose k and a negative n choose k for each k. When n is odd though you get something that's genuinely interesting
I get it now! Thank you two so much!
For n odd "like" terms such as
\begin{pmatrix}5 \\1\end{pmatrix}
and
\begin{pmatrix} 5 \\ 4\end{pmatrix}
will have opposite sign and cancel. You seem to think the same happens with even n. It doesn't:
\begin{pmatrix}4 \\ 1\end{pmatrix}= \frac{4!}{1!3!}
and
\begin{pmatrix}4 \\ 3\end{pmatrix}= \frac{4!}{3!1!}
have the same sign and add
the "middle term" is necessary to cancel all the other terms
Did you actually do that calculation? It is 1- 4+ 6- 4+ 1= -3+ 6- 3= 0.
See #1.
