Verifying Binomial Equations Easily
  • Thread starter Thread starter ehrenfest
    Binomial
The discussion centers on verifying the binomial equation (x+y)^n = (x + y)^(n-2)Q + (x+y)^(n-3)P, where Q and P are defined polynomials. The initial approach involved expanding the equation using binomial coefficients, which was deemed complex rather than "easy." The solution progressed by factoring and rewriting terms, ultimately simplifying to (x+y)^(n-3) multiplied by a polynomial that resolves to (x+y)^3. This method illustrates that while the task may be labeled as simple, it can still require significant effort to achieve the verification. The conclusion emphasizes that the final expression confirms the original equation.
ehrenfest
My book says that one "easily" verifies that
(x+y)^n = (x + y)^(n-2)Q+(x+y)^(n-3)P where
Q = x^2 + xy +y^2
and
P = xy^2 + x^2y
I began by expanding everything into summations with binomial coefficients and it seemed like that method would work but it seemed rather far from easy.
Try factoring.
They always say "easy" when what they mean that it can be done with a relatively small amount of work. I.e., you need no real inspiration... but it's not necessarily "easy", especially if someone tells you it's "easy." That usually just makes it "frustrating." I hate it when authors use that word. Anyways:
<br /> (x^2+xy+y^2)*(x+y)^{(n-2)}<br /> +(xy^2+x^2y)*(x+y)^{(n-3)}<br />
rewrite the (x+y)^(n-2) in the first term as (x+y)*(x+y)^(n-3) and then factor out the (x+y)^(n-3). you get
<br /> (x+y)^{(n-3)}*\left[((x^2+xy+y^2)*(x+y))+xy^2+x^2y\right]<br />
now it should be "easy" to show that the factor in the square bracket is just
(x+y)^3. So, we are done.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
