Binomial Expansion: Coeff of x^29 in (1+x^5+x^7+x^9)
  • Thread starter Thread starter icystrike
    Binomial Expansion
The discussion focuses on finding the coefficient of x^29 in the expansion of (1+x^5+x^7+x^9)^16. Initially, it was noted that there is no x^29 term in the simpler expression (1+x^5+x^7+x^9), but the problem involves raising it to the 16th power. Participants suggest checking unique combinations of powers that sum to 29, specifically using four factors of x^5 and one factor of x^9. The conversation emphasizes calculating the different arrangements of these terms to determine the coefficient. The final consensus confirms the approach and correctness of the solution.
icystrike
Find the coefficient of x^{29} in the expansion of (1+x^{5}+x^{7}+x^{9}).
It is zero: there is no x^{29} term in
<br /> (1+x^{5}+x^{7}+x^{9})<br />
I suppose you are missing some power?
oh yea sorry.
its
<br /> (1+x^{5}+x^{7}+x^{9})^{16}<br />
So you have 16 factors of
multiplying. The first thing I'd do is check which unique combinations of powers give 29. For example, suppose that you open up the brackets. You will encounter terms with four factors of x^5, a factor of x^9 and all 1's otherwise, which gives x^29. Are there any other combinations?
Then, go through them one by one... you are looking for something of the form
x^9 \cdot x^5 \cdot x^5 \cdot x^5 \cdot x^5 \cdot 1 \cdot 1 \ cdot 1 \cdots
(16 in total). How many different orders are there? I.e., when you again think about multiplying out the brackets, how many terms are there that give this expression?
I tried using another method:
Yeah, well, that was essentially what I was thinking of too.
And your answer is correct.
thanks compuchip (=
