Birkhoff's Theorem: Exterior Solution to Einstein's Field Equations
  • Thread starter maxverywell
  • Tags
    Theorem
In summary: Birkhoff's theorem says that a spherically symmetric vacuum solution to Einstein's field equations in exterior region is necessarily static. This means that the interior of a spherically symmetric vacuum solution is static, which is a consequence of Birkhoff's theorem.
maxverywell
197
Now, in wikipedia article it says:
Another interesting consequence of Birkhoff's theorem is that for a spherically symmetric thin shell, the interior solution must be given by the Minkowski metric; in other words, the gravitational field must vanish inside a spherically symmetric shell.
http://en.wikipedia.org/wiki/Birkhoff's_theorem_(relativity)
How is that a consequence of Birkhoff's theorem which speaks only about the exterior region?
You have to consider a thin spherically symmetric shell configuration wherein the source matter is a dirac delta distribution, or at the least confined to a region ##R_1 < r < R_2##. Then the region exterior to ##R_2## will of course have to be Schwarzschild as a consequence of Birkhoff's theorem but note that the region interior to ##R_1## is also spherically symmetric vacuum by hypothesis. Hence Birkhoff's theorem should apply in the interior as well implying that the interior metric is static.
Now the general form of the metric in a static spherically symmetric space-time can be written in appropriate coordinates as ##ds^{2} = -A(r)dt^{2} + B(r)dr^2 + r^{2}d\Omega^{2}##. One can then use the vacuum Einstein equations to deduce that ##B(r) = A(r)^{-1}, A(r) = 1 + \frac{C}{r}##. Now in the interior case ##A(r)## must be well behaved as ##r\rightarrow 0## because the metric has to be non-degenerate, so it must be the case that ##C = 0## otherwise ##A(r)## will necessarily blow up at ##r =0## and this will make the metric degenerate at ##r =0## but by definition the metric must be non-degenerate everywhere.
Likes 2 people
This is quite elegant, y'know?
I should clarify that the reason the argument "no singularity in the interior metric" works is that the interior is completely empty (devoid of all mass-energy). By "everywhere" I meant everywhere in the interior. See e.g. Ohanian p. 301
Hence the geodesics of the interior metric will be those of flat space-time; in particular a test particle freely falling in the interior that is initially placed at rest will remain at rest so it will "freely float".
Thanks WannabeNewton!
Np Max. Make note of post #4 above because it's an important detail I forgot to mention in post #2. The argument that there cannot be singularities in the interior metric (hence no degeneracies given the general form of the metric in post #2) only works here because the interior is devoid of mass-energy. The presence of mass-energy would prevent such a simple argument from being made because for example the Kruskal extension into the interior of a Schwarzschild black hole still finds a geometric singularity in the interior.
1. What is Birkhoff's Theorem and how does it relate to Einstein's field equations?
Birkhoff's Theorem is a mathematical theorem that states that any spherically symmetric vacuum solution to Einstein's field equations must be the Schwarzschild solution. In other words, any spherically symmetric vacuum spacetime is described by the same metric as a black hole, regardless of the specific matter content or energy distribution.
2. What is the significance of Birkhoff's Theorem in general relativity?
Birkhoff's Theorem is significant because it provides a simple and elegant solution to Einstein's field equations for a specific type of spacetime. It also helps us better understand the properties and behavior of black holes, as well as the nature of gravity in curved spacetime.
3. Can Birkhoff's Theorem be applied to non-spherically symmetric solutions?
No, Birkhoff's Theorem only applies to spherically symmetric solutions. In other words, it only holds true for spacetimes that have the same properties in all directions from a central point. Non-spherically symmetric solutions require different mathematical approaches to be described.
4. Are there any limitations to Birkhoff's Theorem?
Yes, Birkhoff's Theorem only applies to vacuum solutions, meaning that there is no matter or energy present in the spacetime. It also does not take into account the effects of quantum mechanics, which may play a role in extreme conditions such as inside a black hole.
5. How has Birkhoff's Theorem been tested and confirmed?
Birkhoff's Theorem has been tested and confirmed through numerous observations and experiments, including the orbits of planets around the sun and the bending of light by massive objects. These observations have consistently shown that the Schwarzschild solution accurately describes the behavior of spherically symmetric vacuum spacetimes.
