Black hole gravity response question
The discussion centers on anomalies related to candidate black holes in binary systems, particularly focusing on unusual orbital behaviors. An important finding is the anomalous orbital velocity effect observed in extreme Kerr black holes, which suggests reduced velocity with decreasing radius for orbiting particles. This phenomenon is linked to resonances in epicyclic frequencies, specifically 3:1 and 3:2 ratios, which have been observed in the Galactic Center black hole Sgr A* and several microquasars. The black hole mass estimates derived from these models align closely with the dynamical masses of Sgr A* and the microquasars studied. The conversation highlights the need for further research and analysis of these intriguing gravitational effects.
Voltage
Can anybody tell me if there are any puzzles or anomalies with respect to candidate black holes? For example if we have a binary system that looks like this:
o O
where the o is a candidate black hole and the O is a star of some typical type and mass, one would observe each object orbiting the other. Does anybody know if there's have been any unusual observations or inferences?
Thanks in advance.
Astronomy news on Phys.org
This is the sort of thing I meant. Can anybody advise or inform please?
http://www.iop.org/EJ/abstract/1742-6596/66/1/012039
Abstract: The recently discovered anomalous orbital velocity effect, which implies a reduced velocity with decreasing radius for an orbiting test particle, is present in extreme Kerr black holes with spin > 0.9953 and radii between 1.05 and 1.78 gravitational radii. In this region a 3:1 resonance between the vertical and the radial epicyclic frequencies occurs, which may lead to quasi-peridoc light variations with two periods differing by a factor of 3. Such variations may have been observed from the Galactic Center black hole Sgr A*. At the same spin but at a larger radius a 3:2 resonance between the two epicyclic frequencies is found as well. Such 3:2 frequencies have been observed in four galactic microquasars. In either case, i.e. the 3:1 or the 3:2 resonance, the black hole mass determined from this model agrees very well with the dynamical mass for Sgr A* and each of the four microquasars. Meanwhile the microquasar GRS 1915+105 has been classified by its X-ray spectrum as an extreme Kerr black hole with a spin > 0.98 [1], which agrees quite nicely with our prediction for the spin, i.e. a = 0.996. Model and observational data are presented and discussed.
I'll perhaps search a variety of papers then print and study.
Publication: Redox-driven mineral and organic associations in Jezero Crater, Mars Article: NASA Says Mars Rover Discovered Potential Biosignature Last Year Press conference The ~100 authors don't find a good way this could have formed without life, but also can't rule it out. Now that they have shared their findings with the larger community someone else might find an explanation - or maybe it was actually made by life.
TL;DR Summary: In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect alien signals, it will further expand the radius of the so-called silence (or rather, radio silence) of the Universe. Is there any sense in this or is blissful ignorance better? In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect...
Thread 'Could gamma-ray bursts have an intragalactic origin?'
This is indirectly evidenced by a map of the distribution of gamma-ray bursts in the night sky, made in the form of an elongated globe. And also the weakening of gamma radiation by the disk and the center of the Milky Way, which leads to anisotropy in the possibilities of observing gamma-ray bursts. My line of reasoning is as follows: 1. Gamma radiation should be absorbed to some extent by dust and other components of the interstellar medium. As a result, with an extragalactic origin, fewer...
