Black Holes and Gravitational Waves
Magister
As far as I know, a black hole is a singularity in the space-time. The space-time becomes so curved that the geodesics can't get out, i.e., the gravitational field becomes so strong that information can not get out.
OK! But what about gravitational waves? As far as I know, gravitational waves are perturbations in the space-time and hence I suppose that they can climb the space-time curvature of the black hole.
I believe that this must be wrong since otherwise the black hole would emit information from inside of the event horizon which I never heard of.
So thinking about this I have come across with some questions. Do the gravitational waves also follow a geodesic in space-time? How can one define a geodesic for the motion of a perturbation of the space-time along this very same space-time? Do the trajectory of a gravitational wave also bend due to the presence of a gravitational field?
Thanks for any answer.
Hello Magister
That is an interesting question. As far as I know one could see, no i'd rather say look at a Black Hole as some object as one with a radius smaller then its Schwartschild radius, but on larger scale say 10 R_S a Newtonian attractor the same as any other of the same mass. So were the black hole suddenly moved because: "hit by a train or so" this information of gravitation change should be send into space as if it were a classical object. You are right, but also light which is emitted at a right angle from the surface also comes out, but gravitational frequencyshift of a black hole or a small neutron star nullify respectivily almost nullify this. Tangentialy emitted light at the schwartschild radius rotates around the black hole and from a small neutron star spirals out many times before being freeed from the surface. I don't know to much about the question if gravitational waves are bent through gravitation in the same way as light. Recent probe send to space measuring gravitational waves gives perhaps answer to that?
greetings Janm
Gravitational waves follow exactly the same geodesics as light does, and therefore cannot escape from within the event horizon. Note, however, that gravitational waves transmit a change in gravity, not gravity itself.
A black hole cannot just spontaneously move, or change its mass, without some external source causing that change; the external source would cause gravity waves.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
