Blackbody radiation - stat mech
In summary, the conversation discusses a system of standing waves that satisfies the wave equation in 3-d. The solution to the equation can be thought of as a plane in 3d space, with two independent directions. Additionally, the condition of div(E)=0 is satisfied due to the lack of charge density in the box. However, there is uncertainty about the connection between this condition and light having two independent polarisations.
sachi
75
we have a hollow cubical box with sides of length a with perfectly conducting walls, such that the electric field tangential to the surfaces of the walls must be zero. we need to show that the system of standing waves:
Ex = Ax*cos(Kx*x)*sin(Ky*y)*sin(Kz*z)*exp(iwt)
Ey = Ax*sin(Kx*x)*cos(Ky*y)*sin(Kz*z)*exp(iwt)
Ez = Ax*sin(Kx*x)*sin(Ky*y)*cos(Kz*z)*exp(iwt)
satisfies the wave equation in 3-d. I can do this. We also need to show that they satisfy the condition that div(E)=0 (I think this is because there is no charge density in the box) provided that there are two independent polarisations for light.
just doing algebra I can get the expression (Kx*Ax + Ky*Ay + Kz*Az) = 0 , but I'm not sure how this connects to light having two independent polarisations (or in fact what it means for light to have two independent polarisiations). any hlpful hints would be appreciated.
Sachi
For a given [tex] (K_x,K_y,K_z) [/tex], you can think of the solution to the equation you derived as a plane in the 3d space [tex] (A_x , A_y , A_z ) [/tex]. How many independent directions are there on such a plane?
1. What is blackbody radiation?
Blackbody radiation refers to the electromagnetic radiation emitted by a perfect blackbody, which is an idealized object that absorbs all radiation that falls on it. This radiation is emitted at all wavelengths and is a result of the thermal energy of the blackbody.
2. How is blackbody radiation related to statistical mechanics?
Statistical mechanics is the branch of physics that studies the behavior of a large number of particles, such as atoms or molecules. Blackbody radiation is closely related to statistical mechanics because it can be explained by the statistical behavior of particles within a blackbody.
3. What is the blackbody radiation spectrum?
The blackbody radiation spectrum is the distribution of electromagnetic radiation emitted by a blackbody at different wavelengths. It follows a specific curve called the Planck curve, which describes the intensity of radiation at different wavelengths.
4. How does temperature affect blackbody radiation?
The temperature of a blackbody is directly related to the intensity and distribution of its emitted radiation. As the temperature increases, the peak of the blackbody radiation spectrum shifts to shorter wavelengths and the overall intensity increases. This is known as Wien's displacement law.
5. What are some applications of blackbody radiation?
Blackbody radiation has various applications in different fields. In astrophysics, the study of blackbody radiation helps in understanding the properties of stars and other celestial objects. In engineering, it is used in the design of thermal radiation shields and in the development of infrared cameras. It also has applications in climate science, as it plays a significant role in Earth's energy balance.
