Boat crossing a stream time taken
To calculate the time taken for a boat traveling at 6 km/h to cross a 1.5 km wide stream flowing south at 4 km/h, the effective speed of the boat across the stream must be determined. The boat's speed across the stream remains 6 km/h, while the stream's current affects its downstream position. The time to cross directly is calculated using the formula time = distance/speed, resulting in 0.25 hours or 15 minutes for one crossing. The return trip would also take the same amount of time, totaling 30 minutes for a round trip. Thus, the overall time taken for the boat to travel directly across the stream and back is 30 minutes.
1508
In still water a boat travels at 6km/h. A stream is flowing south at 4km/h. Calculate the time it would take for the boat to travel directly across the stream and back if the stream is 1.5km wide
As per forum rules, you need to make some attempt. At the very least, post your thoughts so far.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
