Book on String Theory: Start w/ Zwiebach?
Barton Zwiebach's book on string theory is considered an accessible starting point for those with a foundational understanding of general relativity (GR), quantum mechanics (QM), and classical mechanics. A background in GR at the level of Schutz or Hartle, and QM at the level of Griffiths, is deemed sufficient. While knowledge of Heisenberg QM, quantum field theory (QFT), and group theory is not strictly necessary, familiarity with basic quantum principles, special relativity, and tensor calculus is recommended. The book addresses the connection between different quantum mechanics frameworks and includes discussions relevant to particle physics, though prerequisites are kept minimal. There is an inquiry about whether Zwiebach's book covers the derivation of nonlinear GR from string theory, indicating interest in the book's depth regarding advanced topics.
AuraCrystal
Hello,
I was thinking of eventually studying some string theory and I came across Barton Zwiebach's book on the subject. Would this be a good place to start? I know some GR at the level of Schutz/Hartle, Schrodinger QM at the level of Griffiths, Classical Mechanics at the level of Marion & Thornton, and EM.
However, I don't know any Heisenberg QM, QFT, or Group Theory. Would this be a problem in getting through Zwiebach's book? If so, can anyone recommend some books on the subjects I have listed?
Hi Auracrystal,
I was in a similar situation as you. I knew quantum on the level of griffiths, EM with griffiths and some basic mechanics (I used fowles, random book don't ask).
You don't really need GR beyond knowing the linearized form of Einsteins equations and you probably have enough background. You're level of GR is probably more than enough.
I didn't have any background in the Heisenberg picture beyond what I read in Sakurai and really no background in QFT. Group theory won't really be necessary either except for maybe the chapter on particle physics. Overall the prerequisites are kept to a minimal. Zwiebach goes over the connection between the two pictures. You just need a good background in basic quantum, special relativity and tensor calculus.
Thanks for the advice!
Does Zwiebach's book explain string theory's derivation of nonlinear GR?
The book is fascinating. If your education includes a typical math degree curriculum, with Lebesgue integration, functional analysis, etc, it teaches QFT with only a passing acquaintance of ordinary QM you would get at HS. However, I would read Lenny Susskind's book on QM first. Purchased a copy straight away, but it will not arrive until the end of December; however, Scribd has a PDF I am now studying. The first part introduces distribution theory (and other related concepts), which...
I've gone through the Standard turbulence textbooks such as Pope's Turbulent Flows and Wilcox' Turbulent modelling for CFD which mostly Covers RANS and the closure models. I want to jump more into DNS but most of the work i've been able to come across is too "practical" and not much explanation of the theory behind it. I wonder if there is a book that takes a theoretical approach to Turbulence starting from the full Navier Stokes Equations and developing from there, instead of jumping from...
