dean barry
- 311
- 23
Thanks, ill ponder that, back tommorow AM
Dean
Dean
The discussion centers on the mechanics of a bowling ball released without rotation, focusing on the role of friction in converting linear kinetic energy (KE) into rotational KE. The friction force, calculated as f = m * g * µ, acts simultaneously to decelerate the ball and to create torque for rotation. Participants concluded that while some energy is lost to heat due to friction, the primary energy transfer occurs between linear and rotational motion until synchronous speed is achieved, where the ball rolls without slipping.
PREREQUISITESPhysics students, mechanical engineers, and anyone interested in the dynamics of rolling motion and energy transfer in physical systems.
More or less. Similarly with a box sliding along a floor. At the moment it comes to rest, friction falls to zero, in principle. In reality, no body is completely rigid, so the drop to zero does take a short time.dean barry said:The difference in speed between the ground and the ball means a constant sliding friction is in force ?
This then suddenly plummets to zero at synchronous speed ?
The friction only slows the linear motion of the ball (and accelerates the rotational motion) until rolling contact is achieved. At this point frictional force has become zero. In the absence of rolling resistance it would then just keep rolling steadily.THE HARLEQUIN said:after the ball reaches synchronous speed , the friction force still continues to decelerate the ball and the ball decelerates until it reaches 0 velocity
If there's rolling resistance there's no reason why the linear deceleration should be momentarily zero, though it will drop substantially compared with sliding.dean barry said:At synchronous speed, constant linear speed is achieved (momentarily), and then rolling resistance then decelerates the ball to zero ?
No, you've been told that's wrong. It is not split; it applies fully to both simultaneously.dean barry said:Ball enters sliding at given speed,
Friction force (m*g*µ) is split evenly between direct linear deceleration due to sliding friction ( a = f / m ), and torque increasing rotation (which also produces linear deceleration).
dean barry said:So, let's say it was sliding only (like a block instead of a ball), the work done by sliding friction would = friction force * distance travelled.
But if part of that work is involved in ball rotation acceleration, surely it detracts from the overall ?
jbriggs444 said:Is the distance traveled in the sliding case (before the block comes to rest) the same as the distance traveled in the skidding/rolling case (before the ball is rotating at the right rate for its reduced velocity)?
Umm... no.rcgldr said:the rolling ball will slide further because it's rate of linear deceleration is less than that of the sliding box,
Yes. It is always better to analyse, thoroughly, the problem as originally stated (i.e. with the extras all left out) and, when all the juice has been squeezed out of that lemon, start introducing other factors. This thread suffered from extra considerations being added in far too early. haruspex summed it all up nicely.rcgldr said:No, the rolling ball will slide further because it's rate of linear deceleration is less than that of the sliding box, so it will cover more distance while sliding (higher average velocity since the final velocity is not zero).
haruspex corrected this in his next post. - The rolling ball will slide less distance: the rate of deceleration is the same, but the bowling ball stops sliding as soon as it transitions into rolling (still moving forward, but without sliding), while the box slides until it comes to a complete stop.
These type of problems usually ignore issues like rolling friction, so once the ball is rolling, it doesn't slow down.
I'd just like to emphasise one thing you might not have noticed in my post #38.dean barry said:the work done by sliding friction would = friction force * distance travelled
See if you can derive that from the standard starting point: total energy before = total energy after (including that lost to friction etc.)dean barry said:Energy lost to friction = loss of linear KE + Gain in rotational KE
It probably is - but the use of "loss" and "gain" terms make it hard (for me - and possibly others) to appreciate what's going on. It may be better to come up with an equation that just uses the changes in the three components of energy with plus and minus signs? A 'loss' of 'minus' energy can get your brain in a twist and that's what happens if you try to re-arrange your equation. Start with Change in linear KE = ΔKl and let the signs do the work. -ΔKl will mean a loss of linear KE. etc. etc.dean barry said:It is true to say that :
Over the distance described above :
Energy lost to friction = initial linear energy - (final linear energy + final rotational energy). As mentioned previously, the initial linear energy is 1/2 m v^2, while the (final linear + angular energy) = 5/14 m v ^2, which is a loss of 1/7 m v^2. In terms of loss relative to initial energy, it's (1/7 m v^2) / (1/2 m v^2) = 2/7 of the initial energy.dean barry said:Energy lost to friction = loss of linear KE + Gain in rotational KE
That's somewhat backwards as a process.dean barry said:Excellent, thanks, so the model i have is :
Subtract 2/7 of the original linear KE, then calculate the linear : rotating energy split from this remainder
Calculate the final linear velocity.
Loads to go on, thanks for your time everyone.
On what basis?dean barry said:add 5/7 of the friction work done (m*g*k*d) to the rotation KE
You can only say how things will end up and not what is happening during the process. With a high or low correction coefficient, the overall answer is the same. It's only when there is no more energy lost to friction that the 2/7 thing applies.dean barry said:Heres a thing :
I worked a start and step programme.
Start with a small (arbitrary) distance (d) traveled by the ball (say 1 Metre)
If you add 5/7 of the friction work done (m*g*k*d) to the rotation KE, then adjust the linear KE down to balance:
Then calculate the velocity of both.
(surface velocity of the ball)
You can work the distance to obtain the synchronous speed.
And 2/7 of the original KE is lost to friction as you stated.
dean barry said:Im trying to build a behaviour model for the process.
The 5/7 was a stab in the dark, i had attributed 50:50 friction force distribution but it didnt work, but the 2/7 losses thing fell into place when i did.
I had assumed full friction force throughout.
But if at the outset full friction force applies and then diminishes to zero at synchronous speed:
The work done by friction in this distance is ( friction force / 2 ) * distance.
The remaining KE (at synchronous speed) = 5/7 of the original
Ill build the model using these parameters and see how it looks.
Thanks for your patience.
dean barry said:Thanks sophie, I've a better understanding of this problem, though a movie would be a great help.
Appreciate all the assistance.
Yes, of course you are right that the force is zero when there's no relative movement (I guess that would be an instantaneous value) but, when there is movement, I can't see how the force can be any less than the limiting friction as the relative speed is non zero. This assumes that sliding friction is no different from static friction, of course. My reason for saying this is that I can't think what other value it could take than μmg. When a block slides along a surface, this force acts all the time. If μ is high then the acceleration is high (negative). If, as you suggest, the force gets less and less, then you could have the situation where the ball never stops slipping. Is that possible / likely/ according to experience? I am considering the most ideal case here.dean barry said:OK sophie, thanks for your help.
I confess to being somewhat overwhelmed by the response.
Im baffled by your previous post : Friction force is highest when the relative speed is zero (ie synchronous speed)
I assumed that at that point only rolling resistance was present.
Anyhow, ball enters stage left at given constant velocity (ill use 10 m/s) with rotation zero.
Its sliding so linear retardation takes place (not through translation), as it would do in the case of a block sliding.
A torque is applied also so rotational acceleration takes place.
My model assumes that the ball actually acts like part block and part ball, are you with me ?
