Choosing the Right Switch for a Stereo Audio Design: Tips and Tricks
  • Thread starter Thread starter the_android
    Designing
For a stereo audio switch design with two inputs and one output, a Double Pole, Double Throw (DPDT) switch is recommended to handle the four signals involved. Alternatively, using two DPDT switches for each channel can provide additional mixing options. A 4PDT switch, likely a rotary type, is another viable option. The original poster acknowledges prior research before seeking further advice. The discussion emphasizes the importance of selecting the right switch for effective audio signal management.
the_android
hi guys, today i got the hugest brainfade I've ever gotten before. I'm designing a small 2-2-1* audio switch for a friend of mine and i totally forgot which switch i should use. any tips?
*note, 2 input(360, pc) to 1 output (speakers)
Intuiting from context 2-2-1 means that you have two inputs and one output, then a DPDT (Double Pole, Double Throw) switch is what you want. However you probably have _stereo_ {in,out}puts so you need to switch four signals to two signals, which you could do with two DPDT's, one for each channel, making for some fun mixing options. Or find a 4PDT, probably some kind of rotary switch.
yes it's stereo, and i thank thee very much for the reply. and berkeman, you do realize that i actually did some googling before posting here.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
