How Do You Calculate pH After Titration of HOBr with NaOH?
  • Thread starter Thread starter gerry73191
To calculate the pH after titrating 20.0 mL of 0.1 M NaOH into 50.0 mL of 0.14 M HOBr, first determine the concentrations of HOBr and OBr- using stoichiometry from the neutralization reaction. The pH of the resulting solution can be found using the Henderson-Hasselbalch equation, which incorporates the concentrations of the acid and its conjugate base. The initial pH of HOBr is 4.74, and the dissociation constant (Ka) is 2.3e-9. The final pH after the titration is calculated to be 8.24.
gerry73191
20.0 mL of a 0.1 M solution of sodium hydroxide is titrated into 50.0 ml of the 0.14 M HOBr solution. Calculate the pH of the resulting solution.
ph of HOBr is 4.74
Ka is 2.3e-9
[H+] = ka(a/b)
-log[h+] = ph
ka*kb=kw
honestly i have no clue how to do this problem. I already know the answer its 8.24, but I haven't a clue how to get it. can someone point me in the right direction?
thanks
Calculate concentrations of HOBr and OBr- (just from the neutralization reaction stoichiometry), plug these numbers in the Henderson-Hasselbalch equation.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
