Building a 5 Wire Servo Controller
5 replies · 9K views
seang
Hi,
I am supposed to build a controller for a 5 wire servo. I'm having trouble finding information online that appeals to electrical engineering folks.
What are the 5 wires? I suspect there is power and ground, but that leaves 3 unknown connections :eek:
I have a basic understanding of servomotors (though, by no means complete), to the point where I can get a handle on the application circuit in the following datasheet:
http://www.datasheetcatalog.org/datasheet/MitsubishiElectricCorporation/mXyyzzzr.pdf
Maybe someone can help me understand what the 5 connections are in terms of the above circuit? Do you think it would be possible to make a basic controller with a PIC uC?
I know this post is kinda vague, so thanks for any thoughts or help.
Hmm, I don't think it's a stepper. From my experience, you can usually turn a stepper in your hand without much physical resistance. You don't get that dynamo charging sound like you do when you turn a servo. (I get the servo sound, on this one.)
Never mind, forgot some servo motors have error correction for a feedback loop.
I think I might give up on this one. The servos are part of an xyz stage, which is supposed to come with a controller (both the stage and controller are made by the same company). Well, the controller has been missing for many years.
My thought is that the interface is somewhat proprietary; they probably don't want you to figure this one out ;). Thoughts on this?
The 5-wire synchro-resolvers ("servos") I have used had two wires for ac power and return, and the other three wires transmitted/received a 3-phase angular position signal to/from the other synchro. Either synchro could be used as a sender, and the other as a sender. We would put a hand crank on one and the other synchro would follow. I have never used more than two connected together.
Edit: These units were also called selsyns. See Figure 2 in this for wiring diagram:
http://www.navweaps.com/index_tech/tech-051.htm
