Building(or buying) a cheap relay that puts out at least 15hz at low voltage
The discussion revolves around the challenge of building or buying a relay that can output at least 15Hz at low voltage, specifically 9V, while avoiding complex circuitry. Participants explore various approaches to achieve this oscillation, including the use of relays and alternative components.
  • Experimental/applied
  • One participant expresses a desire to build a relay that oscillates at 15Hz without using additional circuitry or components.
  • Another participant argues that the request is impractical, likening it to wanting a light bulb to flash without any additional components.
  • Some participants suggest using two relays or simple components to create an oscillator, while noting that 15Hz is a fast rate for a relay and may lead to wear over time.
  • There are suggestions to consider hobby electronics kits that can produce the desired waveform, with options for both assembly and pre-assembled kits.
  • A method for creating a buzzer circuit using a relay is described, where the relay's contacts open and close to create an oscillating output, but caution is advised regarding voltage spikes.
  • Participants discuss the implications of using relay contacts in series with an induction coil, highlighting the potential for high voltages and the need for additional components to manage arcing and pitting of contacts.
  • Some participants mention the reliability issues of induction coils and suggest looking for older ignition coils that may be more suitable for the application.
  • There are references to historical experiences with ignition systems and suggestions for using a CD ignition circuit with modern components.
Participants do not reach a consensus on the feasibility of the original request. Multiple competing views are presented regarding the practicality of achieving the desired output with or without additional components.
Participants express uncertainty about the specific requirements and limitations of the proposed relay design, including the need for additional components to manage high voltages and the reliability of mechanical contacts in oscillating applications.
Individuals interested in DIY electronics, particularly those exploring relay-based circuits, induction coils, or oscillation mechanisms in low-voltage applications.
ben123324
i want to build a cheap relay that puts out at least 15hz at low voltage. the relay should operate with an input of 9v, and put out 9v but the output should be oscillating at at least 15hz(15 off-on, per second), and please don't tell me to build anything with circuitry or components. thank you.
Your request makes no sense to me. It's like saying: "I want this ordinary light bulb to flash on and off when I plug it in, but I don't want anything else besides the bulb, socket and cord." It quite simply cannot be done.
I'm assuming from your last comment (and your other thread) that you are trying to keep this as simple to build as possible. Can you use 2 relays? (and maybe a couple small components... I'm not sure yet) It might be possible to make an oscillator with a couple of relays.
Also, 15Hz is pretty fast for a relay, even a reed relay. And it will wear out over time from all the mechanical hammering. Can you tell us more about what you want to make? There may be other alternatives.
For example, since you mentioned the "buy" option, you could look at the simple/cheap hobby electronics kits for oscillator kits that put out the waveform you want. Something like this:
http://www.electroniccity.com/shopping/pricelist.asp?prid=512
You said in the other thread that you can solder, so you can assemble your own kit to do what you want. Or the kits are often available pre-assembled, for a few dollars more.
You can make a buzzer circuit from just a relay.
You arrange it so that the relay coil is fed power through a pair of contacts that opens when the coil is activated.
So, the coil gets power, opens the contacts, loses power, closes the contacts, gets power and so on.
Here is a drawing of it. The bottom contact is being attracted to the coil when it is activated.
[PLAIN]http://dl.dropbox.com/u/4222062/buzzer.PNG
The speed of this will vary with the relay and you can take an output between the point shown as output and the bottom battery connection. Battery polarity doesn't matter.
The output will contain large voltage spikes and you should be careful about what you connect it to. It may need diodes and resistors and capacitors to clean up the output.
by that i mean i don't want a cuircuitboard with components. all i want is a device that you put in series with the load so that the battey sends pulses to the load.
thanks that was wat i was looking for, but how would i make, or buy 1 that works for me? i really don't need 15hz more like 2,5,10 or something. I am building an induction coil curcuit, and i need a way to send my 15vdc to the coil pulsed at a rate where i see a steady stream of sparks, but if i can't get that from a relay, il setle for 2-5 sparks per second.
could you show me the best one from here, if i want to send pulses of 9-15v using 9-15v to power the relay itself? link:http://www.skycraftsurplus.com/relayssolenoids.aspx
If you are using the relay contacts in series with a coil (like automobile ignition coil primary), you will be developing very high voltages across the relay contacts whenever they open. The contacts will be carrying a large current when they are closed. The V=L dI/dt voltage will arc and pit the relay contacts, and needs to be controlled by a small capacitor in parallel with the relay contacts. See my simulation at post #3 in the thread
https://www.physicsforums.com/showthread.php?t=330883&highlight=automobile+ignition+coil+simulation
Bob S
Induction coils have their own contacts that open and close to switch the supply on and off.
A Google hunt brought up some great pictures of induction coils.
They are notoriously unreliable as the contacts quickly become dirty and pitted.
You should be able to achieve something with a circuit like this:
[PLAIN]http://dl.dropbox.com/u/4222062/spark%20generator.PNG
This would require a second set of contacts on the relay.
Ignition coils from cars are available at wrecking yards and are cheap if you don't care what car they came off. Try to get the capacitor that was used with the coil. I have shown 0.022 uF because it was on Bob S's simulation, but it must be a capacitor off an ignition system.
You would have to ask for the "old type" of ignition coils as modern cars use different arrangements.
vk6kro said:
Induction coils have their own contacts that open and close to switch the supply on and off...They are notoriously unreliable as the contacts quickly become dirty and pitted.
I went through 3 cars with "old type" ignitions: 1941 Buick, 1949 Ford, and 1956 Olds. At about 10,000 ignition firings per mile, I put many million cycles on the "points". My main problem was the points gap needing adjustment every ~5000 miles, replacement ~15,000 miles. The contacts remained reliable.
An alternate choice is: If you can find a CD ignition circuit on an old car, it can be run directly off a NE555 chip with an open collector NPN transistor output. I still have my old "Mark Ten B" CD ignition circuit I built from a kit ~1970.
Bob S
Bob S
Hi Bob,
An induction coil is one of these:
They had a primative rattling switching contact mechanism to provide the varying flux.
These contacts were unreliable, but the coils themselves were beautifully made and lasted for ever.
They are mainly seen in schools and are still available. An easy way to produce scary sparks.
I have 3 old Model T Ford (buzz) coils with the vibrator (relay) contact mechanism on one end. The coils (primary and secondary) were wound like a solenoid around a stranded iron wire core. I suspect you won't find any of these in junk yards anymore.
Search for photos at eBay "ford model t coil"
Bob S
Ahh! Model T. Now, that was a car. :) Pretty strange to drive, though, I believe.
Did they synchronise the spark with the engine or did they just keep firing the plugs regardless?
The induction coil in the picture above has a piece of soft iron being attracted to the core of the transformer when DC passes through it. This switches the DC supply to the coil off and the cycle repeats.
For some reason this seems to be added as an afterthought and it is usually noisy and erratic.
Ideal machine for instilling a sense of shock and awe into students, though.
i don't think i can get that, but should i substitute with the lowest uF cap i have at the required voltage?
You can probably still get a new one at an auto parts store. They were not expensive.
This is probably better than getting something from an electronics store.
The series resistance of these capacitors would be important and you get good, low, series resistance with an ignition system capacitor.
  • · Replies 31 ·
  • · Replies 21 ·
