Exploring Light in a Vacuum Bulb
In summary, the question is about what would happen if an elliptical shaped bulb, covered from the outside and capable of internally reflecting light, was placed in a vacuum. The asker hopes for an explanation that a layperson can understand, and welcomes all observations and theories. However, it is unclear why the shape is important or how the internal reflection would work. Additionally, without a voltage source, the light bulb would not emit anything. The placement in a vacuum may potentially cause the bulb to break faster due to heat. This scenario may be a thought experiment regarding trapping light in a perfectly reflecting hollow sphere.
Acemave
the question was: if a elliptical shaped bulb , which was covered from outside and internally reflected light in the bulb itself . what would happen if it were placed in a vacuum ? would it emmit light for eternity ?
hope someone would shed some light on the matter ?:) , and explain this to a laymanlike myself? all observation and theories are welcome .
sos
acemave
Welcome to PF!
I'm not really sure of your logic, but if it is covered, it wouldn't emit anything, would it? Anyway, since no reflectors are truly perfect, it would quickly absorb and dissipate the light.
Several things are not clear. Why the elliptical shape? What do you mean by covered from outside? With what? Why should it internally reflect light on itself? The last question makes it sound like a contradiction of something, where there should be none. A light bulb will not emit anything unless energy is supplied from a voltage source.
Plus: How does the placement in a vacuum come into play? It would probably get broken sooner because of its heat.
I think this a version of a thought experiment where you have a hollow sphere, with perfectly reflecting walls, and you trap light inside. Will the light be bouncing back and forth from the walls forever? Can you confirm this, Acemace?
Related to Exploring Light in a Vacuum Bulb
1. What is a vacuum bulb?
A vacuum bulb is a glass container that is designed to hold a vacuum, meaning it has little to no air or gas molecules inside. This creates a low-pressure environment, which is important for certain scientific experiments and technologies.
2. How does light behave in a vacuum bulb?
In a vacuum bulb, light behaves differently than it does in other environments. Without any air molecules to scatter the light, it travels in a straight line until it hits an object or surface. This allows for more precise and focused experiments with light.
3. What is the significance of exploring light in a vacuum bulb?
Exploring light in a vacuum bulb allows scientists to study the properties of light in a controlled environment. This can lead to a better understanding of how light behaves and potential applications in various fields, such as optics and telecommunications.
4. Can light travel in a vacuum?
Yes, light can travel in a vacuum. In fact, light travels faster in a vacuum than it does in any other medium. This is because there are no particles to slow it down or interfere with its path.
5. What other experiments can be conducted in a vacuum bulb?
Aside from exploring light, vacuum bulbs are used for a variety of experiments and technologies. Some examples include studying the behavior of gases, testing the effects of extreme temperatures, and creating specialized electronic components.
  • Classical Physics
