The Bullet Cluster is primarily identified as 1E0657-56, while 1E0657-558 appears to be a less common reference. NED provides information for 1E0657-56 but lacks data for 1E0657-558, suggesting it may be a typo or an alternate designation not widely recognized. The discussion highlights the confusion surrounding the naming conventions of extragalactic objects, likening it to taxonomic issues in biology. The existence of multiple identifiers for the same astronomical object can lead to misunderstandings. Clarification and potential updates to databases may be necessary to resolve these naming discrepancies.
#1
Ranku
433
The Bullet Cluster is referenced as 1E0657-56; but sometimes references quote 1E0657-558. Are they both referring to the same Bullet Cluster?
NED returns Bullet Cluster information for 1E0657-56, but is unable to find anything fro 1E0657-558. I have never seen this used. Where did you find it?
So the answer to the OP's question is yes, 1E0657-56, and 1ES 0657-558 both refer to the same cluster.
#5
Ranku
433
For instance it is referenced in this paper and this is the referenced paper.
FWIW the database has 20 cross-ids, and none match. So either the author of the primary article came up with a new name or it is a typo. And maybe should be added to the database(?) I do not know.
As you can tell the "taxonomy" of extragalactic objects is confusing at first glance. I'm a biologist so I'm used to this kind of taxonomic tangle. We call each one of multiple different biological binomials for the same thing, 'nomen confusum'. For a good reason.
Partial solar eclipse from Twizel, South Isl., New Zealand ...
almost missed it due to cloud, didnt see max at 0710 NZST as it went back into cloud.
20250922, 0701NZST
Canon 6D II 70-200mm @200mm,
F4, 100th sec, 1600ISO
Makeshift solar filter made out of solar eclipse sunglasses
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed).
n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons.
Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
