Bullet Hit Mechanics: Force, Momentum, and Rotation
  • Thread starter Thread starter zoltaaaan
    Bullet Mechanics
The discussion focuses on the mechanics of a bullet impacting a triangular prism-shaped shard and how this affects its motion. When a bullet strikes the shard at its center of mass, it results in straightforward translational motion without rotation. However, if the bullet hits off-center, the shard experiences both translation and rotation, with the axis of rotation determined by combining these motions. The conversation also highlights that a hit farther from the center of mass increases rotational energy transfer while decreasing translational energy. Understanding these dynamics is crucial for accurately simulating the impact and resulting shard behavior.
zoltaaaan
Well hello there! :D
I'm doing a project on graphical simulation of a bullet hitting a glass plate, and I have some describing the way the shards fly off upon impact.
Note that in this calculation I am not yet taking the force of gravity or any forces other than the force of the impact of the bullet.
To be more precise, say my shard is a triangle-based prism as shown in the attached figure. If the bullet hit that shard at the center of its mass, perpendicularly to the plane of the base of the prism, the prism would - given that it doesn't break - receive some momentum and fly off straight along the axis of the initial trajectory of the bullet, without any rotation.
However, should the bullet hit anywhere beside the axis through the mass center of the shard, for example at one of its vertices, as shown on the figure, beside the straight translation, some rotation would also occur.
My question is: where is the axis of this rotation, and what forces (probably inertial) keep the other side of the shard in place.
I hope I made myself clear enough, if not, please let me know and I will try to elaborate further.
Thank you.
It's not clear to me what you're asking. The impulse delivered by the bullet produces a translational acceleration of the center of mass and a rotational acceleration about the center of mass. The instantaneous axis of rotation at any moment can be determined by adding the two motions together. There's no force "keeping the other side in place".
Well you kind of answered my question... :D I had a hunch that it would be rotating around its center of mass, but I had nothing to back that thought up, at least now I have your opinion :D
Could you please also comment on this thought:
I'm guessing that the further the bullet hits from the shard's center of mass, the more energy would be transferred into rotation, and less to translation of the shard. Am I correct?
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
