Bullet Strikes Wheel - find rotations/second
  • Thread starter Thread starter yesiammanu
    Bullet Wheel
The discussion revolves around calculating the rotational speed of a wheel after a lead weight collides with it. The initial approach incorrectly applied energy conservation principles, leading to an erroneous result. It was clarified that while linear momentum is not conserved due to the inelastic nature of the collision, angular momentum is conserved. The correct calculation shows that the angular momentum from the bullet contributes to the wheel's rotation, resulting in a final speed of approximately 0.315 revolutions per second. The key takeaway is the distinction between linear and angular momentum conservation during inelastic collisions.
yesiammanu
The wheel shown in the sketch below, is comprised of two 50.0 cm long thin rods of negligible mass and a thin metal ring with a mass of 10.00 kg, mounted on a very low friction bearing. A 100 gram lead weight is shot horizontally at the stationary wheel with an initial speed of 50.0 m/s and sticks to the rim of the wheel. What is the rotational speed of the wheel plus lead mass immediately after the collision? Give your answer in revolutions/second.
I = mr^2
L = Iω
KE = 1/2 mv^2
KErot = 1/2 Iω^2
1/2 mv^2 = 1/2 Iω^2
1/2(.1 kg) (50 m/s)^2 = 1/2( 10.1 kg )(.25 m)^2 ω^2
ω^2 = (125 kg * m^2 / s^2)/ .315625 kg * ms^2)
ω = 19.9 / s
Rotations = ω/2pi = 19.9/2pi = 3.16 rev/s
The answer is .315 RPS so I'm not sure what I'm doing wrong
yesiammanu said:
1/2 mv^2 = 1/2 Iω^2
Energy is not conserved--there's an inelastic collision taking place.
But what is conserved?
Is linear momentum/angular momentum conserved? I thought you couldn't go between the two
One is, one isn't. Which?
What do you mean?
I'd assume linear momentum isn't conserved because the momentum absorbed would be redirected to the earth, but doesn't the bullet have no angular momentum? I tried to think of treating it as a tangential force but there's no acceleration
Good.
Sure it does. L = r X p.
Since r is the vector position relative to the origin, it would be .25m (where the origin in the center of the wheel, and the radius is .25m) and the p would be linear momentum, m*v, .1kg * 50 m/s = 5 kg * m/s
It's a tangent so the ABsin(theta) is simply AB, and that would be (5 kg * m/s)(.25m) = 1.25 m^2/s
L= Iw, I is MR^2 for a thin cylindrical shell
1.25 m^2/s = (10.1 kg)(.25 m)^2 w
w = 1.98 rad/s
1.98 rad/s / 2pi = .315 rotations per second
Thanks for help.
