Bungee Jumping Physics: Hooke's Law & Potential Energy
  • Thread starter Thread starter Abid Rizvi
    Bungee Physics
The discussion revolves around the physics of bungee jumping, specifically applying Hooke's Law and concepts of potential energy. The original poster describes a scenario involving a daredevil bungee jumping from a height and using an elastic cord to stop his fall, raising questions about the calculations related to the spring constant and the stretching of the cord.
  • Mixed
  • Participants explore the relationship between the length of the elastic cord and its spring constant, questioning how to correctly apply Hooke's Law in the context of varying lengths of the cord. There are attempts to clarify the definitions of variables and the implications of stretching on potential energy calculations.
The discussion has evolved with participants providing insights and corrections regarding the spring constant and its dependence on the length of the cord. Some participants have successfully derived relationships between the lengths and stretching, while others express confusion about the calculations and seek clarification.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is an ongoing exploration of assumptions related to the properties of the elastic cord and how they affect the calculations.
Abid Rizvi
A daredevil plans to bungee jump from a balloon 59.0 m above the ground. He will use a uniform elastic cord, tied to a harness around his body, to stop his fall at a point 13.0 m above the ground. Model his body as a particle and the cord as having negligible mass and obeying Hooke's law. In a preliminary test he finds that when hanging at rest from a 5.00-m length of the cord, his body weight stretches it by 1.65 m. He will drop from rest at the point where the top end of a longer section of the cord is attached to the stationary balloon.
Hookes Law = 1/2 kx^2
Potential Energy = mgx
Okay so for starters I said when he falls out of the balloon he falls a distance x at which he is now not falling.
x = 59-13 = 46
Then I set out to find k for Hookes law. I said mg = ky where y is the 1.65 m. So
k = (mg)/y
I then said r is the actual length of the chord, and L is the length that the chord stretches. So
r + L = x
I then said the total potential energy of the devil is mgx, and the amount of work in opposition to him by the chord is 1/2KL^2 = 1/2 * (mgL^2)/y
I set this equal to mgx: 1/2 * (mgL^2)/y = mgx
= (L^2)/(2y) = x
= L = sqrt(2yx)
solving for L and subtracting it from x to get r (the actual length of the chord) I get 37.3 m. Which apparently is wrong. What am I missing? Thanks in advance
k=mg/y Is the spring constant of an 5 m long chord. What is K for an L m long chord of the same kind?
Also, the potential energy of a stretched spring depends on the change of length (r) instead of the unstretched length (L) as you wrote.
ehild
Hi and thank you for responding
I did set L as the change of length and r as the unstretched length.
Also I just assumed K = mg/y. Does K change because of length?
Imagine a 0.5 m length of chord. Would it stretch to 2.15 m if the fellow hung from it ?
Lol no I suppose not. Ok so K =mg/(stretched length) for a cord. I will try it with this.
Ok so I put K = mg/L instead of mg/y for the chord, and I get L=2x which is obviously incorrect. I'm lost on what to do now...
No, it is still the case that for a given piece of elastic K = mg/(length of stretch). Your problem is how to convert the K for one length of material to the K for a greater length. It's the innate property of the material that's constant. If a given load stretches a rope length L by x, by how much would it stretch a rope of twice the length?
So k=mg/1.65 for the 5 m long chord. Assuming it is r m long, what is the spring constant?
Think: 5 m chord stretches 1.65 m. You bind two 5 m chords together. How much does that 10 m chord stretch?
If the chord is r m long, how much does it stretch by the weight of the man?
ehild
YES! I got it. Okay so from what I understood, if a 5 m chord stretches 1.65 m, a 10 m chord should stretch 3.3 m (=1.65*2). So to do the conversion I need to find the factor to multiply by and that factor is given by f = (r/5) where 5 is the length of the small cord. So mg/fy = K. Putting that back into the original stuff, I get 2.5L^2 = yx(x-L), and therefore L = 25.156 m. So to find the length of the cord r, x- l = r which is about 20.8 which the website accepts as correct. Thank you!
Well done! :)
  • · Replies 16 ·
