What is the acceleration of a buoyant alcohol-filled shell in water?
The discussion revolves around calculating the acceleration of a buoyant alcohol-filled shell in water. The shell has a mass of 0.300 kg and a diameter of 0.250 m, filled with alcohol at a density of 806 kg/m³. The initial calculation yielded an incorrect acceleration of 2.211 m/s². A corrected approach was suggested, leading to a final acceleration of approximately 1.83 m/s² after proper application of buoyancy and mass equations. The conversation emphasizes the importance of careful calculations and using a consolidated equation to minimize errors.
AG1189
-A thin spherical shell of mass 0.300 kg and diameter 0.250 m is filled with alcohol ( = 806 kg/m3). It is then released from rest on the bottom of a pool of water. Find the acceleration of the alcohol filled shell as it rises toward the surface of the water.
FB-(M1+M2)g=(M1+M2)a
M1=0.3kg, r=0.125 m, V= (4*pi*r^3) /3,
M2 = pV = (806*V), FB = pVg = (1000)(V)(9.8)
. After finding FB, I plugged it back into the equation and got 2.211 m/s^2. This answer was wrong, could someone please tell me if I am using the wrong equation, or if I just screwed something up.
It looks like you might have just done something wrong in your calculations...I set it up like this:
<br /> \sum{F} = \rho_{water} V g - \rho_{alcohol} V g - mg = (m + \rho_{alcohol} V) a<br />
<br /> a = \frac{g(\frac{4}{3} \pi r^3 (\rho_{water} - \rho_{alcohol}) - m)}{m + \rho_{alcohol} \frac{4}{3} \pi r^3}<br />
and I got a number a little lower than yours. Maybe it was rounding? Generally I like to get everything in one equation and then plug it all in at once to reduce the chance of that sort of mistake.
it worked out, thank you very much. I got 1.829711 m/s^2, I think that's what you got. :smile: :smile:
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
