Is the Bar of Gold Real? Using Buoyancy to Determine Density
The discussion revolves around determining whether a bar of gold is genuine by measuring its weight in air and water. The buoyant force, calculated as the difference in weight (400 N), is used to find the volume of the bar, which is equal to the volume of water displaced. By applying the equation for buoyant force, participants clarify that the density used should be that of water, leading to the calculation of the bar's density. Ultimately, the calculated density of the bar is found to be 5.00 x 10^3 kg/m^3, indicating it is not gold. The problem emphasizes the importance of understanding buoyancy and density in identifying materials.
BrainMan
A man decides to make some measurements on a bar of gold before buying it at a cut-rate price. He find that the bar weighs 2000 N in air and 1600 N when submerged in water. Is the bar gold?
B = density* V* g
I tried to use the equation B = density *V*g and use 400 N for the buoyant force to solve for the density and compare it to the density of gold. I wanted to use 400 N because that is the difference in the two weights and would be the force of the water pushing up. However, this problem doesn't give the volume so I am not sure how to solve this problem. The answer the book gives is 5.00 x 10^3 kg/m^3 as the density and says that it is clearly not gold. [/B]
What quantity did you calculate from the 400N using the equation? I don't just mean the number, I mean what does that number represent?
If you don't understand what I'm asking, state exactly what each of the terms in your equation stands for when you apply it to this question.
Likes BrainMan and Maged Saeed
Try to use two equation :
One is of the actual weight {give the mass in terms of the density times volume} equate it by the actual weight.
The other is of the buoyant force {give also the mass in term of the Density times volume} equate it by the difference.
And solve for your two unknown
The equation means the buoyant force is equal to the density times the volume times the acceleration due to gravity. I used the 400 Newtons as the buoyant force because it is the difference in weights meaning the water has to be pushing up 400 N to decrease the weight of the block from 2000 N to 1600 N.
Right, but the density of what?
Likes BrainMan
The density should be the density of the block right?
What does Archimedes' principle state?
Likes BrainMan
OK so the density is actually the density of the fluid not the density of the block. So how do I find the density of the block using this equation?
One step at a time.
You know the density of water, so what do you calculate from the 400N?
Likes BrainMan
haruspex said:
One step at a time.
I'm not entirely sure. Is it the pressure?
No.
You are applying the equation B = density* V* g with B = 400N. You now understand that the density is that of water. What quantity does the equation then give you?
Likes BrainMan
haruspex said:
No.
The volume of the water displaced
Right. And what will that also equal here?
Likes BrainMan
Would it equal the volume of the bar?
Yes. You are told it is completely submerged.
Likes BrainMan
OK I figured it out. I just found the volume of the metal bar and divided the mass by the volume. Thanks a lot!
