But what happens when the object is on an inclined surface?
When a 30kg block is placed on a surface inclined at 30 degrees, the pressure it exerts can be calculated by determining the normal force. The normal force (Fn) is found using the equation Fn/Fg = cos(30 degrees), resulting in a normal force of 254.6N. This value is then divided by the area of force, which is 0.008m², yielding a pressure of approximately 3.2 x 10^4 Pa (Pascals). Understanding these calculations is essential for analyzing forces on inclined surfaces. The discussion effectively clarifies the process of calculating pressure in this context.
frigid
In this particuliar situation a 30kg block with an area of force of 80cm squared is standing on a surface which 30 degrees inclined relative to the floor. How do you calculate the pressure it exerts?
You need to find the component of the force that is normal to the surface where it acts, in order to find the pressure.
Ok so Fn/Fg = cos(30deg) = 0.866
0.866 * 30kg * 9.8 = 254.6N
254.6 / 0.008m^2 = 3.2 X 10^4
Like this?
Good work, that's it! :smile:, btw N/m^2 = Pa (Pascal).
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
