Chemistry  Butane vs Pentane: Which is Liquid & Why?
Butane is a gas at room temperature, while pentane is a liquid due to its higher molecular mass, which leads to stronger London dispersion forces. The discussion highlights that larger molecules have more electrons, resulting in increased dispersion forces and higher boiling points. As molecular mass increases, the strength of intermolecular interactions also increases, requiring more energy to separate the molecules. This explains why pentane remains liquid at room temperature, whereas butane does not. Understanding these principles clarifies the behavior of these hydrocarbons in different states.
magma_saber
There are two compounds, butane and pentane. one is a liquid at at room temp and the other is gas. which is a liquid and why?
I'm guessing that its pentane. For a gas to liquify, it should have a have a higher melting point, meaning that it has a higher freeing point. They both only have london dispersion forces but pentane has a greater mass so it should have a higher melting point.
More or less correct, although I am not sure if mentioning just 'greater mass' will do. Why do molecules of greater mass interact stronger?
im guessing as the mass of the molecules increases, so does the strength of the dispersion force acting between the molecules, so more energy is required to weaken the attraction between the molecules resulting in higher boiling points.
OK, but why higher mass means higher dispersion forces?
Hint: higher mass - more electrons, or less electrons?
magma_saber said:
im guessing as the mass of the molecules increases, so does the strength of the dispersion force acting between the molecules,.
it also means that the molecules move more slowly at any given temp
so since there are more electrons, higher dispersion forces?
Yes.
thanks for all the help.
larger molecules have the same kinetic energy as smaller molecules at a given temp but they have more surface area for intermolecular forces to act upon.
