C++ Object-Oriented Assignment: Test Your Motion Knowledge
In summary, the player has to answer questions in a given time limit. If they answer correctly, they are given points, and if they answer incorrectly, they lose a point. There are a number of questions per player, and the default number can be changed by passing a different number on the command line when starting the program.
nemisis
Hi Everyone I have a object oriented C++ assignment which is due this week and I have no idea as to how start it....
This program prints a motion verb ( fly, run, swim, crawl, walk, or roll ), waits for a second,
then prints the name of an entity and repeats the verb (for example: fly ..1s.. pigeon fly!.. ).
The player has ½ second to type ‘y’ for yes or ‘n’ for no. (case insensitive)
- If the answer is correct, the player scores, if incorrect, or if there was no answer within the ½ second, the
player looses a point. When correct, all the motions the entity can perform are printed.
- When wrong, Ka..BOOM! is printed instead.
The default number of questions per player is 20, but the number can be changed by passing a different
At the end of the run the player’s score (and the score of previous players if there were any) is printed, the
question: “Another player (Y/N): “ is asked. The game exits if ‘n’ is typed.
The output should look something like this:-
Player 1 starting.
You must answer with the letter ‘y’ for YES, or ‘n’ for NO.
Press [Enter] when ready to start:
1 – fly pigeon fly!.. y
- I walk - I fly
2 – swim Wheelbarrow swim.. n
- I roll
3 – crawl ball crawl!..
Ka...BOOM!
4 – fly plane fly!.. y
- I roll - I fly.
5 – run boat run!.. n
- I roll.
6 – walk engine walk!..
Ka..BOOM!
7 – roll stone roll!.. y
- I roll.
16- crawl time crawl!.. y
- I crawl - I fly.
17- swim goose swim!.. n
Ka..BOOM!
18- run lizard run!.. y
- I run - I crawl.
19- run nose run.. y
- I run
20- fly goose fly!.. y
- fly - I walk – I run – I swim.
Player 1 *** score: 16 ***
Well done! Start another player (Y or N)? y
Player 2 starting
1 – crawl giraffe crawl!.. y
Ka..BOOM!
I am not good at all in coding so i tried and made an overview of what the main driver should look like
main{
start_function(a,b)
check here wherther the player is old or new------>Connector
where a = value of yes or no, taken by cin>>
if the vaue is yes...
you are back in main >>>here
now start the for...while/Do...while[(condition for 1/2 min)& this shld take care of the initial 30 seconds also]
call function2(loop for 20 questions)
else if right answer add a point
Also call a function to print what the object does (for ball, it will be I ROLL)
keep adding ( + or -)points in a variable
End for loop of questions
display final score
ask to replay ------------>connector
But as said above I have no idea on the coding part of the whole program and would like some help here please
Also apart from this can anyone suggest a good compiler, I use Visual Basic C++ if that's good
Thanks in advance:cool:
Technology news on Phys.org
man if this was in VB, it would take 2 mins
If you were doing it in a non-OO language, one obvious way to go would be encode the definitions of what objects can do what actions in a 2-D array, and the names of the objects and actions in two 1-D arrays. Apart from the data, the program would then be about 20 lines long (including comments).
But in C++, you can make it far more complcated than that by using templates to create collections of classes with multiple inheritance, or whatever... :rolleyes:
yup C would have been easier, I got friends who are doing Java too..... but C++ is one language in which i can't get the codes, it just freaks me out. but I am still strying, working on the code and will post it when i haven made some(or any) progress at all.
Anyways thanks guys for replying still if any1 can will help a lot:rolleyes:
If you have borland turbo cpp 3, then you could use dos.h which has a delay(time in ms) function. However, I don't know what the corresponding function would be in ansi cpp or whatever.. I am still getting used to it...
Anyway, you could create a class which stores the question, and its answer, use the delay function (or one like it), and test the input... sorry, I am not much help...
Srry i use Microsoft visual studio 8...... hehehehehe guess i am too lost to remember that too, anyhow anybody who can code the game program in c++ still find it tough to understand
so anybody has anything to tell me? i don't have much time left with other things in hand......
here is something new
Motion.h
Code: ( cpp )
#ifndef MOTION_H
#define MOTION_H
#include <iostream>
#include <string>
using namespace std;
class Motion
friend ostream &operator << (ostream &out, const Motion &m);
public:
Motion();
virtual ~Motion(){};
virtual string *toString() const = 0;
virtual bool contains(const string *key) const = 0;
#endif
Motion.cc
Code: ( cpp )
#include <iostream>
#include <sstream>
#include <string>
#include "Motion.h"
out << "- I " << m.toString();
return out;
}FlyMotion.h
Code: ( cpp )
#ifndef FLYMOTION_H
#define FLYMOTION_H
#include <iostream>
#include <string>
#include "Motion.h"
class FlyMotion : public Motion
public:
static FlyMotion* instance();
virtual string *toString() const;
virtual bool contains(const string *key) const;
protected:
FlyMotion();
FlyMotion(const FlyMotion&);
~FlyMotion(){};
private:
static FlyMotion *inst;
// return &inst;
#endif
FlyMotion.cc
Code: ( cpp )
#include <iostream>
#include <sstream>
#include <string>
#include "FlyMotion.h"
FlyMotion* FlyMotion::inst = 0;
FlyMotion::FlyMotion()
inst = 0;
FlyMotion* FlyMotion::instance()
if(inst == 0)
inst = new FlyMotion;
return inst;
string* FlyMotion::toString() const
ostringstream outStr;
outStr << Motion::toString() << "fly " << flush;
return outStr.str();
After compiling FlyMotion.cc this is what i get
Flymotion.cc: In member function 'virtual std::string* FlyMotion::toString() const'
line30: cannot convert 'std::basic_string<char, std::char_traits<char> std::allocator<char> >' to 'std::string*' in return
Related to C++ Object-Oriented Assignment: Test Your Motion Knowledge
1. What is an object in C++?
An object in C++ is a self-contained unit that contains both data and functions. It is a fundamental concept in the object-oriented programming paradigm, where objects are used to model real-world entities and their interactions.
2. What is the difference between a class and an object in C++?
A class is a blueprint or template for creating objects, while an object is an instance of a class. In other words, a class defines the characteristics and behaviors of an object, while an object is a specific manifestation of those characteristics and behaviors.
3. How do you create an object in C++?
To create an object in C++, you need to first define a class with the desired properties and behaviors. Then, you can use the class to create objects by using the 'new' keyword and assigning the object to a pointer variable.
4. What is encapsulation in C++?
Encapsulation is a principle of object-oriented programming that involves bundling data and functions within a class and controlling access to them through public and private interfaces. This allows for better data protection and code organization.
5. How do you achieve inheritance in C++?
Inheritance in C++ is achieved by using the 'inheritance' keyword in the class definition. This allows a new class to inherit the characteristics and behaviors of an existing class, known as the base class. The new class is called the derived class.
  • Math Proof Training and Practice
10K
9K
