C/C++ How Do I Combine Multiple C++ Programs into One?
  • Thread starter Thread starter zarentina
    Programs
The discussion centers around a user seeking assistance with combining four C++ programs that generate right triangle patterns using nested loops. The user has successfully created individual programs for two triangles but encounters difficulties when attempting to merge them. The goal is to produce an output of four right triangles, each separated by a tab, while maintaining their distinct shapes.The user shares their code for the first two triangles, which display increasing and decreasing patterns of asterisks. However, when trying to combine these outputs, the user notes that the triangles appear as a single block rather than separate shapes. Suggestions from other participants emphasize the importance of properly structuring the nested loops and utilizing tab spacing effectively to achieve the desired output format. The discussion highlights the need for clarity in code indentation and logical flow to facilitate better understanding and debugging. Overall, the focus is on achieving the correct visual output through effective use of loops and formatting in C++.
zarentina
Hello all, I am still new to C++ and was instructed to write four programs all a bit different and eventually combine them into one using a series of nested for loops to get an out put that resembles but goes to 10 lines of output not 5: *NOTE* all these will be separated by a tab cout<<"\t"
**Sorry for this the spaces were not showing up between the outputs, they are essentially 4 right triangles rotated and spaced by a tab.**
I have all of the individual programs written, and I can combine the second two without any hiccups yet when I try to combine the first two I begin to run into trouble.
My code for the first two is as follows;
#include<iostream>
using namespace std;
int main ()
int i,j,k, range=10;
for (i=0;i<10;i++)
for (j=0; j<=i; j++)
cout<<"*";
cout<<endl;
system("pause");
return 0;
and the second is:
#include<iostream>
#include <iomanip>
int main ()
for (i=0;i<10;i++)
for (j=10; j>i; j--)
cout<<"*";
cout<<endl;
system("pause");
return 0;
I'm starting to think maybe my programs for the first two outputs are incorrect? For the second two I simply removed the "cout<<endl;" and replaced it with cout<<"\t"; but this doesn't seem to work for the first two.
Any advice would be greatly appreciated!
Thanks,
Z
p.s sorry for the lengthy post :/
Technology news on Phys.org
It won't hurt if you will explain what the four programs should do, and what the combined program should do.
Post you sources using code tags:
[noparse]
Code:
int main()
  return 0;
[/noparse]
is displayed as
Code:
int main()
  return 0;
Sorry about that, the four codes will combine which produces an output of four right triangles rotated and printed on the same lines. Such as was in my original post, yet for some reason those got pushed together and made it seem as one block of *'s not four triangles.My first program is the initial triangle.
Code:
 #include<iostream>
int main ()
for (i=0;i<10;i++)
cout<<"*";
cout<<endl;
system("pause");
return 0;
My second program is the second triangle
Code:
 #include<iostream>
#include <iomanip>
int main ()
for (i=0;i<10;i++)
cout<<"*";
cout<<endl;
system("pause");
return 0;
My goal is to combine them into one program using for loops while they remain in triangle shape separated by a tab.
Thanks,
Now that you're using code tags, your code would be more understandable if you indented it in a way that shows the logical structure, rather than having every line start at the left margin. I have done this with your code.
Code:
#include<iostream>
int main ()
   for (i=0;i<10;i++)
         cout<<"*";
      cout<<endl;
   system("pause");
   return 0;
Code:
#include<iostream>
#include <iomanip>
int main ()
   for (i=0;i<10;i++)
         cout<<"*";
      cout<<endl;
   system("pause");
   return 0;
Thanks,
May be help with you.
Code:
#include <iostream>
#define MATRIX_SIZE 10  //change it to any size you want to show at here
int main()
	int i,j;
	for (i = 0;i < MATRIX_SIZE;i++)
		for (j = 0 ; j < i+1; j++)
			cout<<"*";
		//cout<<" ";   //I think may be this line is what you want
		cout<< "\t";
		for ( ;j <= MATRIX_SIZE ; j++)
			cout<<"*";
		cout<<endl;
	system("pause");
	return 0;
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
