C Program Help: Count & Sort Word Occurrences in File
The discussion revolves around a C programming challenge where participants are attempting to create a program that counts and sorts word occurrences from a file. The scope includes coding issues, debugging, and sorting algorithms.
  • Homework-related
  • The initial poster describes their program's intended functionality and shares their current implementation, highlighting issues with sorting and segmentation faults.
  • One participant suggests using a bubble sort method instead of qsort, emphasizing the need to compare word occurrence counts.
  • Another participant provides a modified compare function for qsort but notes that it may lead to segmentation faults, indicating potential pointer issues.
  • Several participants discuss debugging strategies, including adding print statements to identify where the segmentation fault occurs and commenting out sections of code to isolate the problem.
  • There is a mention of the importance of understanding memory access and pointer management in C programming to avoid segmentation faults.
Participants express varying opinions on the best approach to sorting and debugging, with no consensus on the most effective solution to the segmentation fault issue. Multiple strategies for debugging and sorting are proposed, indicating a lack of agreement on a single method.
Participants note potential limitations in the current implementation, such as pointer errors leading to segmentation faults and the need for proper memory management. The discussion also highlights the importance of correctly implementing sorting algorithms and understanding the implications of using different data structures.
KV305
C program help!
Hey guys I am having trouble completing this C program. Its suppose to ask the user to enter a file to read from, read the file, count how many times each word appears and print the results in a different file(also user input) arranged from high occurrence.
Heres what i have so far
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
typedef struct AWORD
char wordname[50];
int count;
}a_word;
a_word nword(char* words)
a_word new;
strcpy (new.wordname, words);
return new;
int compare (words.wordname, words[j].wordname)
if (words.count < words[j].count)
return -1;
else if (words.count > words[j].count)
return 1;
else
return 0;
int main(int argc, char *argv[])
int i = 0,j = 0,k = 0, m = 0, count = 0,count2 = 0, count3 = 0, wrdcnt = 1,$
char cur, cur2[50], file1[25], file2[25], list[1000][k], *buffer;
FILE *pFile, *pFile2;
printf("Please type the name of the input file:\n ");
scanf("%s",file1);
printf("%s",file1);
pFile = fopen(file1, "r");
printf("Please type the name of the output file:\n ");
scanf("%s",file2);
pFile2 = fopen(file2, "r");
while (cur != EOF)
cur = fgetc(pFile);
if (cur != ' ')
list[m][k] = cur;
fprintf(pFile2, "%c", list[m][k]);
k++;
if (cur != '\n' && cur != '\0')
count2++;
if (cur == '\n' || cur == '\0')
wrdcnt++;
else
if (cur == ' ')
wrdcnt++;
m++;
k = 0;
if (cur == '\0')
fprintf(pFile2,"%s", &cur);
else
fprintf(pFile2, "\n");
fclose(pFile);
fclose(pFile2);
a_word words[wrdcnt];
for (i = 0; i < wrdcnt; i++)
fgets (cur2, 50, pFile2);
words = nword(cur2);
printf("words[%d] is %s", i, words.wordname);
printf("\n");
count3 = wrdcnt;
for (j = 0; j < count3; j++)
buffer = words[j].wordname;
if (strcmp(buffer, words.wordname) == 0)
count++;
words[j].count = count;
count = 0;
printf ("\nWord Counter Program Starting...");
printf("\nWord Counter Program Finished. Check %s file\n", file2);
for (i = 0; i < j; i++)
if (strcmp(words[j].wordname, words.wordname) == 0)
same = 0;
break;
else
same = 1;
if (same == 1)
printf ("%d\t%s", words[j].count, words[j].wordname);
fprintf(pFile2, "%d %s\n", words[j].count, words[j].wordname);
fclose(pFile2);
return 0;
I haven't sorted yet. we are suppose to use qsort but i don't think my compare function is right. Any help would be greatly appreciated. Thank you.
You have to create a list of words and a number for each as you have done (AWORD).
You then need to do a bubble sort - going through your list of words swapping over any pair that are the wrong way round - you do that multiple times until there are no swaps - then you know it's done.
So you need to compare a pair of integers - the number of times each word occurs in each pair.
The declaration for the compare must use a void *. (it can't cope with overloading)
You will be passing it a pair of integers so you need to cast each to a const void* in the qsort call.
Then your declaration will look like:-
int compare (const void *count1, const void *count2)
//then you cast it back to the type you want - you can do that on-the-fly
// I think you can see where it goes from here
if ((int)count1==(int)count2) return 0; //etc.
Ok so far i altered the program and gives no errors but when i try to run it it says
"Segmentation fault"... any ideas?
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
char wordname[50];
int count;
}a_word;
a_word new;
return new;
if ((int)count1<(int)count2) return -1;
if ((int)count1>(int)count2) return 1;
int i = 0,j = 0,k = 0, m = 0, count = 0,count2 = 0, count3 = 0, wrdcnt = 1,same;
char cur, cur2[50], file1[25], file2[25], list[1000][30], *buffer, sorted[1000];
scanf("%s",file1);
printf("%s",file1);
scanf("%s",file2);
while (cur != EOF)
cur = fgetc(pFile);
if (cur != ' ')
list[m][k] = cur;
k++;
count2++;
wrdcnt++;
else
if (cur == ' ')
wrdcnt++;
m++;
k = 0;
if (cur == '\0')
else
fclose(pFile);
fclose(pFile2);
printf("\n");
count3 = wrdcnt;
count++;
count = 0;
same = 0;
break;
else
same = 1;
if (same == 1)
fclose(pFile2);
m=0;
while (pFile != NULL)
fscanf (pFile2 , "%s" , &sorted[m]);
m++;
qsort(sorted,m,sizeof(int),compare);
fclose(pFile2);
pFile2 = fopen(file2, "w");
fprintf(pFile2,"%s", sorted);
return 0;
Are you in the same class as the person who started this thread?
If you're getting a segmentation fault, you are probably attempting to access memory (via a pointer) that your program is not allowed to access. It's time to learn how to use a debugger.
Put extra printf() statements in the program so you can pin down exactly where the segmentation fault is occurring:
"I got to checkpoint #1.
I got to checkpoint #2.
I got to checkpoint #3.
ERROR: Segmentation fault."
It means you are attempting to read or write to a part of the memory outside your own program. Usually a pointer error (accessing memory location zero because a pointer is null for example).
Try temporarily commenting out sections of your program till you locate the line giving the error - then look carefully at any pointers involved.
Doesn't your debugger automatically stop at error points?
  • · Replies 21 ·
