Solving Perfect Number Program in C
  • Thread starter Dili
In summary: Usually only 0 is used. The return statement is the last thing in the function, so if it's going to return a 0 or 1, nothing will happen after that. But if it were to return a different number, the function would terminate immediately.
Dili
I need to write a program to check whether a number is perfect
eg: 6=1+2+3 , 28=1+2+4+7+14
i wrote one, but it doesn't work. also I've seen programs written with different preprocessors, we are required to write it on stdio.h and math.h
#include<stdio.h>
#include<math.h>
int main()
int a,b,c,d,i;
scanf("%d",&a);
for(i=1;i<a;i++)
b=a%i;
if(b==0)
c=0;
c=c+i;
if(c==a)
printf("perfect\n");
return 1;
Technology news on Phys.org
Few mistakes in variable initialization and placing of parentheses. Here is the modified correct version. Make sure you understand the logic.
#include<stdio.h>
#include<math.h>
int main()
int a,b,c,d,i;
scanf("%d",&a);c=0;
for(i=1;i<a;i++)
b=a%i;
if(b==0)
c=c+i;
if(c==a)
return 1;
Heh. Here's a version you can't turn in, but which is far faster; it uses the Euclid identity of perfect numbers.
Code:
#include<stdio.h>
#include<math.h>
int is_prime(n) {
  int i,root;
  if (!(n&1))
    return n == 2;
  if (n%3 == 0)
    return n == 3;
  if (n < 25)
    return n > 1;
  root = (int)sqrt(n);
  for (i = 5; i <= root; i += 6)
    if (n%i == 0 || n%(i+2) == 0)
      return 0;
  return 1;
int main() {
  int even_part, odd_part;
  scanf("%d",&odd_part);
  even_part = 1;
  while (!(odd_part&3)) {
    odd_part = odd_part >> 2;
    even_part = even_part << 2;
  if (!(odd_part&1)) {
    odd_part = odd_part >> 1;
    even_part = even_part << 1;
  if (even_part << 1 == odd_part + 1 && is_prime(odd_part))
  return 0;
Even faster and even cheatier, for 32-bit machines:
Code:
int main() {
  int n;
  scanf("%d",&n);
  if (n == 6 || n == 28 || n == 496 || n == 8128 || n == 33550336)
  return 0;
Thank you very much arunbg. I am not good at C programming.
I do now understand the placing of brackets and c=0.
If no bother can you explain what is the difference between return 1 and return 0
Ive used them but with no real understanding
Thanks again
int main() {
int n;
scanf("%d",&n);
if (n == 6 || n == 28 || n == 496 || n == 8128 || n == 33550336 || n == 8589869056)
return 0;
Lol...nice one.
Don't worry about it. These are error codes that the program returns, but they won't display or do anything unless they're checked by an outside program. 0 is supposed to mean "terminated normally" and anything other than 0 is supposed to mean "terminated with some kind of error".
1. What is a perfect number?
A perfect number is a positive integer that is equal to the sum of its proper divisors (factors excluding itself). For example, 6 is a perfect number because its proper divisors are 1, 2, and 3, and 1 + 2 + 3 = 6.
2. How do you solve a perfect number program in C?
To solve a perfect number program in C, you can use a loop to find the proper divisors of a given number and add them together. Then, you can check if the sum is equal to the original number to determine if it is a perfect number or not.
3. Can you provide an example of a perfect number program in C?
Yes, here is an example of a perfect number program in C:
#include <stdio.h>
int main() {
    int num, i, sum = 0;
    printf("Enter a positive integer: ");
    scanf("%d", &num);
    for (i = 1; i < num; i++) {
        if (num % i == 0) {
            sum += i;
    if (sum == num) {
        printf("%d is a perfect number.", num);
    } else {
        printf("%d is not a perfect number.", num);
    return 0;
4. What is the time complexity of a perfect number program in C?
The time complexity of a perfect number program in C is O(n), where n is the given number. This is because the loop used to find the proper divisors runs n-1 times in the worst case scenario.
5. Can a negative number be a perfect number?
No, a negative number cannot be a perfect number. Perfect numbers are defined as positive integers, and negative numbers do not have proper divisors. Additionally, the loop used in a perfect number program in C would not work for negative numbers since it starts at 1 and only checks numbers up to the given number.
