C program: reading chars then ints
  • Thread starter Thread starter Math Is Hard
    Program Reading
The discussion revolves around a C programming assignment that requires reading characters until an "=" is encountered, followed by reading an integer. Participants express confusion about handling cases where non-integer characters are input after the "=" sign. The original code meets basic specifications but lacks error handling for non-integer inputs. Suggestions include using the ungetc() function to push characters back onto the input stream or reading characters into an array for further processing. The conversation highlights the need for clarification on assignment requirements and explores methods to enhance the program's functionality.
Math Is Hard
Staff Emeritus
The assignment states: "Write a code fragment that reads and discards all characters from standard input until it encounters a "=", and then reads the following characters as an int."
I have a couple of problems:
1) reading char values as int, for instance if I input abc=123 there's no problem, but if I input abc=abc, then there's trouble. I was thinking the ASCII value would be read and stored, but it's not happening.
2) the instruction "reads the following characters as an int". If I input ABC=ABC, should the program only end up printing the value of C as the integer?
Here's what I have so far - I am including the whole program. Thanks for your advice.
#include <stdio.h>
int main(void)
char mychar;
int myint;
while((mychar = getchar())!= '=')
continue;
scanf("%d", &myint);
printf("%d", myint);
return 0;
It seems your program meets the specification. The specification does not instruct you to do any kind of type-checking on the characters themselves to see if they are decimal numerals.
Although it seems your program meets the spec, the spec is admittedly incomplete (it would be unacceptable in industry!). If I were you, I'd call the professor and make sure (s)he didn't intend to provide any more specifics.
- Warren
Thanks, Warren. I will email my prof about this and see if I can get more clarification.
New specs
My teacher said if I wanted a challenge I should code the assignment to accept either an integer or a character after the '=' sign. I thought maybe I could write this so that if characters are entered I could display the ASCII value of the first one entered. But now I am getting stuck since I used scanf() to read an integer I don't know how to handle a character being entered.
thanks.
#include <stdio.h>
int main(void)
char mychar;
int myint;
while((mychar = getchar())!= '=') //discard all until = is read
continue;
if (scanf("%d", &myint) == 1)
printf("That was an integer\n");
printf("It's value is %d\n", myint);
else
printf("That was NOT an integer\n");
printf("The ASCII value of the first character is...\n");
// now I am stuck
return 0;
The easiest way is to use ungetc() to push the character back onto the stream. That way you can "peek" at it, make a decision about it, then call scanf on the stream.
Alternatively, you can read your chars into an array and then use sscanf on the array.
- Warren
ungetc() huh? That's a new function for me. Cool- I am intrigued - I am going to play with that. Thanks!
I hadn't thought about using an array, either. We are just starting to work with those. hmmm...
Hrm, the istream classes have a "peek" function; stdio.h doesn't have an equivalent? :frown:
