Calc II - Integration of Partial Fractions
The discussion revolves around solving the integral of a rational function using partial fractions. The user struggles with the decomposition of the fraction, particularly in determining the correct form of the numerator for the irreducible quadratic term. Participants clarify that the numerator must be a polynomial of degree one less than the denominator, leading to the realization that a first-degree polynomial is needed instead of a constant. The correct decomposition is established as A/(x+1) + (Bx+C)/(x^2-x+1). The user expresses gratitude for the clarification and feels more confident in understanding partial fractions.
demersal
Hi everyone, here is a new partial fractions question I just cannot understand:
\int\frac{x^{3}}{x^{3}+1}dx
Partial Fractions, difference of perfect cubes, polynomial long division
\int\frac{x^{3}}{x^{3}+1} dx
\int1 dx + \int\frac{-1}{x^{3}+1} dx
x + \int\frac{-1}{(x+1)(x^{2}-x+1)} dx
\frac{A}{x+1} + \frac{B}{(x^{2}-x+1)}
A(x^{2}-x+1) + B(x+1) = - 1
If I use coefficients:
x^{2}: 0=A
x: 0 = B-A
: -1 = A+B
These don't add up! Also, using critical values leads me to a similar problem. What am I doing wrong in my strategy of attacking these partial fractions??
Thank you for your time and help, you all are so wonderful!
\frac{A}{x+1}+\frac{B}{(x^{2}-x+1)}
Remember that when you decompose the fraction, the numerator must be a general polynomial with degree one less than that of the denominator. What I'm getting at is that the numerator in your "B"-term is wrong. What should it be instead?
Hmm, I don't quite understand what you are saying. I thought I was just supposed to multiply the numerator by the denominator and cancel. Is there another concept I am missing?
If the denominator is linear, the numerator must be a constant. If the denominator is an irreducible quadratic, the numerator should be a ********** (hint: not a constant)
The numerator of each term must be a polynomial of degree one less than the degree of the denominator. x^2-x+1 is a 2nd degree polynomial, so the numerator for that term should be a first degree polynomial; Bx+C.
In your second term, you just put a B in the numerator. But that is a zeroth order polynomial when you have a second order polynomial in the denominator. So instead of just B, you need to put in an arbitrary first order polynomial. What is another name for a first order polynomial?
Right gabbagabbahey. Notice that the largest exponent in the denominator is 2. So the largest exponent in the numerator should be 1 (i.e. one less than 2).
So it should be Bx?
ohh I see gabbagabbahey, I should have a Bx and a separate C over the same denominator?
You should have:
\frac{A}{x+1}+\frac{Bx+C}{(x^{2}-x+1)}
Yes. By "general" or "arbitrary" we mean that you have to include all the terms. e.g. for a second order polynomial you'd have
Ax^2+Bx+C.
You must include all the lower order terms too (i.e. the 2nd (A), 1st (B) and 0th (C) terms).
Ok! I got it now! Thank you both! Hopefully I'll never have to post about partial fractions again :)
  • · Replies 105 ·
