Calculate Displacement at Any Frequency: f_modal, d_modal, f_actual
To calculate displacement at any frequency based on modal frequency and maximum displacement, a proposed formula is d_actual = (f_actual/f_modal)*d_modal. However, this approach may not be accurate, as displacement is not directly proportional to frequency due to the non-linear nature of the resonance curve. The relationship between displacement and frequency can be approximated for small intervals, but the proportionality constant varies depending on the specific frequency and damping characteristics. Clarification on whether the context involves forced oscillations and the definition of modal frequency is necessary for accurate analysis. The discussion highlights the need for careful interpretation of simulation data from tools like Inventor Simulation Studio.
ncr7
So I have been trying to figure out how much an object is displaced when subjected to certain frequencies. If I know the modal frequency and max displacement at modal frequency can I find displacement at any frequency?
I was thinking maybe using ratios you could do the following,
modal frequency: f_modal
actual frequency: f_actual
Displacement at modal frequency: d_modal
Displacement at actual frequency: d_actual
Would this be correct?
The output kind of makes sense I guess...
say if your modal frequency is 2548.67 Hz creates 14.89mm displacement, and you want to know at 15 Hz. Giving a displacement of .08 mm.
Quite vague what you are trying to find.
are you talking about a system undergoing forced oscillations? And if this is the case, by f_modal do you mean one of the the resonant frequencies?
If this is the case, the displacement is not proportional to the frequency. The resonance curve is not a straight line. You can approximate it as such for small frequency intervals. But even if you do this, you may have something like
d-d_resonance= A(f-f_resonance),
for a specific small frequency interval.
The proportionality constant depends on where on the curve you do the approximation and how narrow is the resonance curve (which in turn depends on the damping).
If you mean something completely different, never mind. Just give the details.
I guess there would be a function in this case. I am working with inventor simulation studio and it gives a displacement at natural or modal frequencies. Although I am unsure if that data is even correct because inventor maybe giving meaningless data.
Is there a way to analyze displacement if the natural frequency is given?
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
