Calculate the coefficient of friction of a box sliding down a hill?
The problem involves a block sliding down a hill with a 20° slope, starting with an initial speed of 6 m/s and coming to a stop after traveling 11 m. The goal is to determine the coefficient of kinetic friction between the block and the hill.
  • Participants discuss using free body diagrams and the conservation of energy to analyze the forces and energy changes involved. There are questions about the roles of kinetic and potential energy, as well as the impact of friction on energy conservation.
Participants are exploring different approaches to relate energy changes to the coefficient of friction. Some have suggested equations involving kinetic and potential energy, while others are questioning the assumptions about energy conservation in the presence of friction. There is ongoing clarification regarding the initial and final energy states of the block.
There is a discussion about the effects of friction on mechanical energy conservation, and some participants express confusion regarding the definitions of kinetic and potential energy in this context.
nerdgirl14
A block slides down a hill. The hill has a gentle 20° slope with respect to
the horizontal. The block has an initial speed of 6 m/s. If the block comes to a stop
after traveling a total distance of 11 m along the slope, what is the coefficient of kinetic
friction between the block and the hill?
F=ma
Fkk*n
The first thing I did was draw a FBD. The box is going forward in the positive direction so the kinetic friction is acting in the opposite direction. There is force of gravity acting on the box and normal force, these forces are in the opposite direction on y axis. My x-axis with was with respect to the slop, so kinetic friction is in the negative direction and the box is in position direction, on the x axis.
Now I don't know what to do next...help?
Use conservation of energy.
Okay so use
1/2*m*v2=m*g*h
and I solve for m, this way then I can find gravity and find the two components of gravity. The y component of gravity will give the normal force. But then how do i find the kinetic friction?
What is initial energy and what is the final energy of the block. The difference is work done, which is friction.
Ok wouldn't the m cancel out with the conservation of energy?
Yes, All have m as factor.
[itex]KE=\frac {1}{2}mv^2[/itex]
[itex]PE=mgh[/itex]
[itex]friction=μN=μmgCosθ[/itex]
Oh I see now
So I can set up the equation like this:
1/2mv2-mgh=μmgCosθ
Isolating for μ:
μ=(v2/2-gh)/gcosθ
μ=(6m/s2/2-(9.80 m/s2)(11m))/(9.80 m/s2)cos 20°
μ=-9.75
Is this correct?
Your equation should be both sides with equal units, joules.
Your initial energy should be PE+KE.
How come the initial energy is PE+KE? I thought originally the box was sliding down so all energy is KE and then it comes to a stop so all energy is PE
Mechanical energy is not conserved in this problem; there is friction.
There is always both kinetic and potential energy, even though at some points one or the other may be zero. Of course, by `always' I mean always when there is something around to give rise to potential energy.
Work-Energy Principle.
Never mind.
9K
  • · Replies 16 ·
