Calculate the convolution between these functions
11 replies · 2K views · last reply
Telemachus
Hi there. I must calculate the convolution between these functions
[tex]f(t)= e^{-t} H(t)[/tex]
[tex]g(t)=e^t H(t)[/tex] H(t) the unit step Heaviside function.
So I have to find: [tex]f \star g[/tex]
This is what I did:
[tex]f \star g=\displaystyle\int_{-\infty}^{\infty}e^{-\lambda}e^{t-\lambda}H(\lambda)H(t-\lambda)d\lambda=\displaystyle\int_{-\infty}^{\infty}e^{t-2\lambda} \left [ H(\lambda)-H(\lambda-t) \right ] d\lambda=[/tex]
[tex]=\displaystyle\int_{-\infty}^{\infty}e^{t-2\lambda}H(\lambda)d\lambda-\displaystyle\int_{-\infty}^{\infty}e^{t-2\lambda} H(\lambda-t)d\lambda=\displaystyle\int_{0}^{\infty}e^{t-2\lambda}d\lambda-\displaystyle\int_{t}^{\infty}e^{t-2\lambda} d\lambda=\displaystyle\int_{0}^{t}e^{t-2\lambda} d\lambda=-2e^{-t}+2e^{t}[/tex]
Is this fine?
Hi Telemachus! :smile:How did you get from:
[itex]H(\lambda)H(t-\lambda)[/itex]
to:
[itex][ H(\lambda)-H(\lambda-t)][/itex]That just doesn't seem right. :confused:
I think that the product [itex]H(\lambda )H(t-\lambda )[/itex] is zero if [itex]\lambda <0[/itex] and also 0 if [itex]t<\lambda[/itex], and so the integral would become:
[tex] \int_{0}^{t}e^{t-2\lambda}d\lambda[/tex]
Sorry, I made a mistake.
Hi I like Serena. I've realized that [itex]H(\lambda)H(t-\lambda)[/itex] its equal to 0 for all lambda outside the interval [0,t], and then its easy to get the same result using a sum with the Heaviside function, I get the [itex]H(\lambda)[/itex] and subtracted all what I didn't want using another Heaviside function, but as hunt_mat said it can be reasoned on that other way, which is the same, using the definition for the function. Maybe that mid step was redundant.
Oh yes, I see now.
But what if t < 0?
And btw, I believe your last integration step is not quite right...
I get a different factor in the final answer. ;)
Oh, I haven't think about what happens for t<0. But I've seen that always appear an Heaviside factor for this kind of integrals, but I don't know why.
The answer you get is [tex](-2e^{-t}+2e^{t})H(t)[/tex]?
I see, I have another mistake, I've made as if I was differentiating :P
So the answer is: [tex](\frac{-e^{-t}+e^{t}}{2})H(t)[/tex]?
Explain me how it is to be reasoned to get the Heaviside function as a factor there.
Right! That took care of the integration step. :wink:
And yes, you'd get a Heaviside function in your answer as you surmised.
(Btw, ever hear of the sinh function? It matches rather nicely.)
As for negative t.
You considered the interval [0, t] and checked the Heaviside product for different values of lambda, which is good.
But if t < 0, you'll get the intervall [t, 0].
You should check that as well for different values of lambda.
If necessary you can try it for instance with t = -2 and lambda = -3, -1, +1 (that's what I did).
You'll see! :smile:
Edit: on a more intuitive note, your function f and g are zero for negative t.
This means that their convolution will be zero as well.
Alright, for negative t I have
[tex]H(-t-\lambda)=1,\lambda\leq{-t}[/tex]
[tex]H(-t-\lambda)=0,\lambda\geq{-t}[/tex]
And by the other hand I have
[tex]H(\lambda)=1,\lambda\geq{0}[/tex]
[tex]H(\lambda)=0,\lambda<0[/tex]
So its zero for all negative t?
I've seen your edit note now, thank you very much Serena :)
