Calculate the Dirac delta function integral
The discussion revolves around calculating the integral of the Dirac delta function, specifically ##\delta(x^2 - 3x + 2)##, which has two spikes at x = 1 and x = 2. Participants emphasize the importance of splitting the integral around these spikes to evaluate it correctly. A substitution method is suggested to simplify the delta function, leading to discussions about the correct limits of integration and the implications of negative gradients in the context of the integral. The conversation concludes with a clarification on the properties of integrals, particularly regarding the sign change when swapping limits.
PRASHANT KUMAR
https://1drv.ms/w/s!Aip12L2Kz8zghV6Cnr8jPcRTpqTX
My question is in the above link
Can you draw a graph of ##\delta(x^2 -3x+2)##?
https://1drv.ms/w/s!Aip12L2Kz8zghWCxSwKUHyOsZE-6
here is the the graph of this function
So, it has two spikes?
yes it has
yes it has
Okay, so does that not give you a clue as to how to evaluate the integral? Hint: trying splitting the integral.
Note: you'll also have to think about a substitution to get the ##\delta## function into a simpler format.
https://1drv.ms/w/s!Aip12L2Kz8zghWJU31OqLM79se67
I did not get this Note: you'll also have to think about a substitution to get the ##\delta## function into a simpler format.[/QUOTE]
[/QUOTE]
Think about how to calculate, for example:
##\int_{-\infty}^{+\infty} f(x)\delta(x^2)dx##
it will be f(0)
it will be f(0)
Try the substitution ##y = x^2##.
In fact, a simpler example to try first is:
##\int_{-\infty}^{+\infty} f(x)\delta(2x)dx##
okay i got it
when y =2x then dy = 2 dx so the integral will be 1/2 f(0)
is the discussion over?
I was at the dentist!
So, you have to do something with that quadratic in the delta function.
what is wrong if i do it like this
##\int_∞^1 (x^2+1) δ(x^2-3x+2) \, dx##+##\int_1^2(x^2+1) δ(x^2-3x+2) \, dx##+##\int_2^\infty(x^2+1) δ(x^2-3x+2) \, dx## (in the first integral the limits will be from - ∞ to 1)
= 0+2+5=7
since in the first integral the dirac delta function is zero and in the second and third it will be one
= 0+2+5=7
You have the same problem that ##\delta(x^2 - 3x + 2) \ne \delta(x)##. That first function is not the Dirac Delta function, it's a composition function and doesn't have exactly the same properties as the Dirac Delta function.
so now if i consider ##x^2-3x+2 = y## then it will give me (2x-3)dx=dy and if i substitute dx=##\frac{dy}{2x-3}##
x will become ##\frac{3\pm\sqrt{1+y}}{2}## and ##x^2##= ##\frac{(10+y)\pm6\sqrt{1+y}}{4}##then my integral will look like
##\int_{-\infty}^{+\infty}\frac{(\frac{(10+y)\pm6\sqrt{1+y}}{4}+1)δ(y)}{\pm\sqrt{1+y}}\,dy##
here if we take + signs into account then the answer comes out to be 5 and if we consider - signs then the answer is -2 which is not appropriate because the integral of dirac delta function should be a unit step function and which is one if y is greater than or equal to zero and everywhere else it is zero so the positive 5 should be considered as correct answer . i think so
is this correct?
##δ(x^2-3x+2)≠δ(x)## because δ(x) has only one spike at zero while ##δ(x^2-3x+2)## has two spikes at 1 and 2 .
But i have a doubt what is the need of equating these two?
= 0+2+5=7
This was better. You need to split the integral before you look at substitutions. I would do the first integral from ##0## to ##3/2## and the second from ##3/2## to ##3##, say. That seems a lot neater.
Then you can use the ##y## substitution. Although, there is also a trick to leave the x-function as it is. Since you are not going to integrate it, it won't change. This is what I mean:
With ##y = x^2 - 3x + 2 = (x - 3/2)^2 - 1/4## and ##dy = (2x - 3)dx##
##\int_0^{3/2}(x^2 + 1) \delta(x^2 - 3x + 2)dx = \int_2^{-1/4} \frac{x^2 +1}{2x-3} \delta(y) dy = -\int_{-1/4}^2 \frac{x^2 +1}{2x-3} \delta(y) dy = -\frac{x^2 +1}{2x-3}|_{y=0} = -\frac{x^2 +1}{2x-3}|_{x=1} = 2##
Notice that because ##2x-3 = -1## you get same answer,. This is a coincidence. If you change the quadratic it won't be the same.
how did you chose the limits of integration from 0 to 3/2 and 3/2 to3
They can be anything, as long as they cover the two zeroes of the quadratic. ##0.9 - 1.1## and ##1.9 - 2.1## would have done just as well.
Can you see the problem trying to do the quadratic substitution across the whole range? And why you should split the integral first?
##-\int_{-1/4}^2 \frac{x^2 +1}{2x-3} \delta(y) dy## why did you put a negative sign here?
yes i think the problem in this case arises because of the two spikes of the function so there is a need to split the integral so that we can solve it separately for each one.
The integral with respect to ##y## came out the "wrong" way. The lower limit was greater than the upper limit. In general, you need to look out for this when integrating:
##\int_a^b = - \int_b^a##
So, for example:
##\int_1^{-1}\delta(x)dx = -1##
I could have avoided this by having ##y = -(x^2 -3x +2)## in that integral. Then the limits would have been the right way round (with respect to ##y##) and the negative sign would have come from ##dy##.
So, for example:
But if we consider ##y = -(x^2 -3x +2)##then our dirac delta function will look like δ(-y) is that okay?
@PRASHANT KUMAR even at this level graphs help. I have a nice graph of ##x^2-3x +2##, so I can see clearly what the function is doing about the zeros and what happens when I substitute ##y## It is easy to miss that the function has a negative gradient around ##x=1## so the natural integral substitution comes out the wrong way.
Good point. Best to stick with the way I did it first time!
so where does the solution lie?
yes it has negative gradient but i could not link these two : natural integral and negative gradient
So, for example:
##\int_1^{-1}\delta(x)dx = -1## i think this should be 1
  • · Replies 31 ·
  • · Replies 33 ·
  • · Replies 25 ·
