Calculate the field within a hole on a charged sphere
The discussion revolves around calculating the electric field at the center of a positively charged circular piece placed on a uniformly charged negative hollow sphere. It is suggested that the electric fields from the circular piece and the hollow sphere will cancel each other out, leading to no locally generated field at the center. The participants explore the idea that the remaining electric field from the hollow sphere extends radially. They conclude that the fields from both the disk and the sphere can be treated as superimposing, allowing for a combined calculation of the total electric field at the center. The overall consensus is that the fields interact in a way that can be analyzed using principles of superposition and the characteristics of charged planes.
Aesteus
If you have a uniformly-charged negative hollow sphere of charge, with a positive circular piece of charged shell superimposed on the outside, what is the electric field in the center of the circular piece? Also what part of the field going through the piece's center is locally generated?
EA=q/ε ... E=(q/ε)*1/(4*pi*r^2)
I assume that none of the field will be locally generated, because the circular-positive piece will totally cancel out with the field of the sphere. I'm not sure where to go from there though, as I would think the remaining sphere's field would extend radially.
Hint:
The circular piece creates the same magnitude, but opposite direction electric field on the two faces. The rest of the sphere would create the same field in these infinitesimally separated points.
What is the total field inside the charged sphere?
Alright so I'm guessing that because the fields point in opposite directions, they superimpose on each other, and because the circular-charged regions are essentially flat that we can treat them as planes of charge. Thus the field going through the disk is essentially the same at any arbitrary point such that the field through its center is E=E(disk)+E(sphere). What do you think?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
