Calculate the Force of a Certain Push
  • Thread starter Thread starter Darkstr958
    Force Push
To determine the minimum force required to keep a 5kg book from sliding down a wall when pushed at a 25-degree angle, it is essential to resolve the applied force into its x and y components. The force of gravity acting on the book is 49N, and the static friction is calculated using the coefficient of static friction of 0.76. The net force must equal zero for the book to remain at rest, meaning all forces must balance out. Two equations can be established: one for the horizontal component (F cos 25º) and one for the vertical component (F sin 25º), allowing for the calculation of the normal force and the applied force. This approach provides a systematic method to solve for the minimum force needed.
Darkstr958
A person exerts a force 25 degrees to the horizontal on a 5kg book resting against a vertical wall. If the coefficient of static friction is .76, what is the minimum force that the person must exert to keep the book from sliding down the wall.
force of friction= coeffecient of static friction * normal force
fg=mg
I know the net force must be zero for the book to be at rest, so all the forces have to cancel each other out. Also, the force of gravity is 49N. I also know you need to resolve the force of the push into its x and y components since its at a 25 degree angle. normal force should be opposite the force of the push along the x-axis, and the force of gravity should be opposite the force of friction plus the force of the push in the y direction, but I don't seem to have enough information to find out many of these values.
Welcome to PF!
Hi Darkstr958! Welcome to PF! :smile:
(have a mu: µ and a degree: º :wink:)
Darkstr958 said:
I know the net force must be zero for the book to be at rest, so all the forces have to cancel each other out … but I don't seem to have enough information to find out many of these values.
Call the force F.
You have two equations, one with F cos25º, and one with F sin25º. You also have friction = µsN, so you have two unknowns (F and N) and two equations. :smile:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
